Kurio Xtreme Power/Volume Buttons Replacement
    1. Kurio Xtreme Power/Volume Buttons Replacement, Back Panel: step 1, image 1 of 1
      • Remove the rubber case by beginning to peel from one of the top corners and continue peeling until the cover is completely removed.
      Ask FixBot
    2. Kurio Xtreme Power/Volume Buttons Replacement: step 2, image 1 of 2 Kurio Xtreme Power/Volume Buttons Replacement: step 2, image 2 of 2
      • Unscrew the four 4 mm black screws using a Phillips #000 screw driver.
      • There are two screws on each side of the device (four total).
      Ask FixBot
    3. Kurio Xtreme Power/Volume Buttons Replacement: step 3, image 1 of 3 Kurio Xtreme Power/Volume Buttons Replacement: step 3, image 2 of 3 Kurio Xtreme Power/Volume Buttons Replacement: step 3, image 3 of 3
      • Insert the plastic opening tool in between the edges of the blue front casing and black back casing.
      • Slide the plastic opening tool around the perimeter of the device. This may require that you repeatedly run the opening tool up and down the edges of the device.
      • Be sure not to break any of the plastic clamps along the edges of the device when removing the back cover.
      • Carefully lift the back panel off of the rest of the device.
      Ask FixBot
    1. Kurio Xtreme Power/Volume Buttons Replacement, Power/Volume Buttons: step 4, image 1 of 1
      • Remove the three 4 mm screws on the motherboard with a Phillips #000 screwdriver.
      Ask FixBot
    2. Kurio Xtreme Power/Volume Buttons Replacement: step 5, image 1 of 2 Kurio Xtreme Power/Volume Buttons Replacement: step 5, image 2 of 2
      • Remove the orange data display ribbon wire above the battery by prying open the ZIF connector with the plastic opening tool.
      Ask FixBot
    3. Kurio Xtreme Power/Volume Buttons Replacement: step 6, image 1 of 2 Kurio Xtreme Power/Volume Buttons Replacement: step 6, image 2 of 2
      • Remove the orange data display ribbon wire to the left of the battery by prying open the ZIF connector with the plastic opening tool.
      Ask FixBot
    4. Kurio Xtreme Power/Volume Buttons Replacement: step 7, image 1 of 1
      • Remove the speakers out of the plastic molds by lifting up the black and red wires.
      • Be careful not to disconnect the black and red wires from the motherboard.
      Ask FixBot
    5. Kurio Xtreme Power/Volume Buttons Replacement: step 8, image 1 of 2 Kurio Xtreme Power/Volume Buttons Replacement: step 8, image 2 of 2
      • Remove the motherboard by lifting it out of the casing. Set it upside down below the casing.
      • The motherboard will still be connected to the battery and the speakers.
      Ask FixBot
    6. Kurio Xtreme Power/Volume Buttons Replacement: step 9, image 1 of 3 Kurio Xtreme Power/Volume Buttons Replacement: step 9, image 2 of 3 Kurio Xtreme Power/Volume Buttons Replacement: step 9, image 3 of 3
      • Remove the volume buttons and/or power button by soldering them at their bases.
      • Volume down
      • Volume up
      • Power
      Ask FixBot
Mallory Myers
1,190 Reputation
7 Guides authored
Baylor, Team 6-10, Williams Fall 2015 Member of Baylor, Team 6-10, Williams Fall 2015
BU-WILLIAMS-F15S6G10
3 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 26
All Time: 1,165
