Kurio Xtreme Back Panel Replacement
    1. Kurio Xtreme Back Panel Replacement, Back Panel: step 1, image 1 of 1
      • Remove the rubber case by beginning to peel from one of the top corners and continue peeling until the cover is completely removed.
      Ask FixBot
    2. Kurio Xtreme Back Panel Replacement: step 2, image 1 of 2 Kurio Xtreme Back Panel Replacement: step 2, image 2 of 2
      • Unscrew the four 4 mm black screws using a Phillips #000 screw driver.
      • There are two screws on each side of the device (four total).
      Ask FixBot
    3. Kurio Xtreme Back Panel Replacement: step 3, image 1 of 3 Kurio Xtreme Back Panel Replacement: step 3, image 2 of 3 Kurio Xtreme Back Panel Replacement: step 3, image 3 of 3
      • Insert the plastic opening tool in between the edges of the blue front casing and black back casing.
      • Slide the plastic opening tool around the perimeter of the device. This may require that you repeatedly run the opening tool up and down the edges of the device.
      • Be sure not to break any of the plastic clamps along the edges of the device when removing the back cover.
      • Carefully lift the back panel off of the rest of the device.
      Ask FixBot
Mallory Myers
1,190 Reputation
7 Guides authored
Baylor, Team 6-10, Williams Fall 2015 Member of Baylor, Team 6-10, Williams Fall 2015
BU-WILLIAMS-F15S6G10
3 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 21
All Time: 737
