Kurio Touch 4S Battery Replacement
    1. Kurio Touch 4S Battery Replacement, Battery: step 1, image 1 of 1
      • Make sure to open the back cover easily using the plastic opening tool.
      Ask FixBot
    2. Kurio Touch 4S Battery Replacement: step 2, image 1 of 3 Kurio Touch 4S Battery Replacement: step 2, image 2 of 3 Kurio Touch 4S Battery Replacement: step 2, image 3 of 3
      • Remove back cover by prying away from the device.
      • The easiest place to remove the cover is from the bottom and top, then try to open it from the right and left sides.
      • Open it gently. Do not open it with too much pressure, so that the plastic back cover do not break.
      Ask FixBot
    3. Kurio Touch 4S Battery Replacement: step 3, image 1 of 3 Kurio Touch 4S Battery Replacement: step 3, image 2 of 3 Kurio Touch 4S Battery Replacement: step 3, image 3 of 3
      • To remove the battery, make sure the four 5mm Philips screws on each side of your device is open using the Phillips #1 Screwdriver.
      Ask FixBot
    4. Kurio Touch 4S Battery Replacement: step 4, image 1 of 1
      • After you remove your four screws use your plastic opening tool to help you open the plastic cover of your device.
      Ask FixBot
    5. Kurio Touch 4S Battery Replacement: step 5, image 1 of 1
      • Use the plastic opening tool to remove the battery from its place.
      • The battery is glued into the device. So try removing it gently.
      Ask FixBot
    6. Kurio Touch 4S Battery Replacement: step 6, image 1 of 1
      • Remove the two wires using soldering tool to detach your bad battery from the device .
      • Gently remove the wires one by one. Do not damage the head that is glued into the motherboard.
      • For more information on how to solder and desolder the wire Click here
      Ask FixBot
3 other people completed this guide.
Khalid AlTamimi
275 Reputation
2 Guides authored
USF Tampa, Team 6-5, Brown Winter 2015 Member of USF Tampa, Team 6-5, Brown Winter 2015
USFT-BROWN-W15S6G5
3 Members
60 Guides authored
2 Guide Comments
do you know where to buy a replacement battery ?
Phil Bowring - Reply Share
Any idea where I can purchase a replacement battery?
Brooke Lonsdale - Reply Share
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 13
All Time: 1,934
