Kurio Motion Battery Replacement
View statistics:
Past 24 Hours:
4
Past 7 Days:
14
Past 30 Days:
56
All Time:
330
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: No estimate
Difficulty: Difficult
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Needs More Images
A few more images would make this guide's procedures crystal clear.
Introduction
Go to step 1 ↓
Is your tablet not turning on or has a shorter battery life? Then it is time to replace the battery and this guide will help you in doing so. This guide does require soldering so please refer to this guide.
Tools
    1. Kurio Motion Battery Replacement, Battery: step 1, image 1 of 2 Kurio Motion Battery Replacement, Battery: step 1, image 2 of 2
      • Use the Phillips #0 Screwdriver to remove four 5mm screws from sides of the device.
      Ask FixBot
    2. Kurio Motion Battery Replacement: step 2, image 1 of 1
      • Use the Ifixit opening tool to pry open the device to remove the back of the Kurio Motion.
      • It is held together with tabs so don't try to pry too hard or it may break.
      Ask FixBot
    3. Kurio Motion Battery Replacement: step 3, image 1 of 1
      • Remove the tape covering the tape from the edges of the battery.
      Ask FixBot
    4. Kurio Motion Battery Replacement: step 4, image 1 of 1
      • To disconnect the battery from the motherboard, you will have to desolder the connections.
      Ask FixBot
Yazeed Ayyad
447 Reputation
3 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 14
Past 30 Days: 56
All Time: 330
