Kurio 10S Battery Replacement
    1. Kurio 10S Battery Replacement, Back Cover: step 1, image 1 of 1
      • Turn the device over and place it with the screen down on a flat surface that is clean so the screen does not get scratched.
      Ask FixBot
    2. Kurio 10S Battery Replacement: step 2, image 1 of 2 Kurio 10S Battery Replacement: step 2, image 2 of 2
      • Locate the four screws, two on each side.
      • Using the philips head screwdriver, carefully remove each screw and keep them together in a safe location.
      Ask FixBot
    3. Kurio 10S Battery Replacement: step 3, image 1 of 1
      • Once all screws are removed, use a spudger to get under a corner and unclip the hooks.
      • Once the spudger is under the cover, slide it all the way around the device, pushing lightly into the device making sure it stays under the cover until all the clips are removed.
      • The back cover is difficult to remove, so do not be afraid of using some force once all of the clips have been removed.
      Ask FixBot
    4. Kurio 10S Battery Replacement: step 4, image 1 of 1
      • The back cover should then be able to easily be removed from the device and you should see the battery and other internal components.
      Ask FixBot
    1. Kurio 10S Battery Replacement, Battery: step 5, image 1 of 1
      • Remove the electrical tape surrounding the battery.
      • Take care when working near the wires under the electrical tape and around the battery, as they may be fragile.
      Ask FixBot
    2. Kurio 10S Battery Replacement: step 6, image 1 of 1
      • Once the electrical tape is removed there should be a metal bar across the battery.
      • Using a philip's head screwdriver, remove the screws on both ends and take off the metal bar.
      Ask FixBot
    3. Kurio 10S Battery Replacement: step 7, image 1 of 2 Kurio 10S Battery Replacement: step 7, image 2 of 2
      • Locate the red and black wire connections where the battery is connected to the motherboard.
      • Now remove the red and black wires by soldering the ends of the wires off where they connect to the motherboard.
      • Caution: Soldering irons run hot. When removing solder from the board, the iron heats up the components, so be careful when using one.
      Ask FixBot
2 other people completed this guide.
Timothy Kramer
325 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 19
All Time: 1,571
