Up to 20% off select tools
Kurio 10S Back Cover Replacement
Views: 1.1K
View statistics:
Past 24 Hours:
2
Past 7 Days:
14
Past 30 Days:
86
All Time:
1,138
Comments: 0
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 15 minutes
Difficulty: Easy
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Incorrect Tools
Help make this guide better by using the correct tools in images and/or text.
Tools
Introduction
Go to step 1 ↓
Removing the back cover allows easy access to many components inside of the device allowing you to fix other issues that may have popped up. This guide will show you how to remove your back cover and replace it if desired.
    1. Kurio 10S Back Cover Replacement, Back Cover: step 1, image 1 of 1
      • Turn the device over and place it with the screen down on a flat surface that is clean so the screen does not get scratched.
      Ask FixBot
    2. Kurio 10S Back Cover Replacement: step 2, image 1 of 2 Kurio 10S Back Cover Replacement: step 2, image 2 of 2
      • Locate the four screws, two on each side.
      • Using the philips head screwdriver, carefully remove each screw and keep them together in a safe location.
      Ask FixBot
    3. Kurio 10S Back Cover Replacement: step 3, image 1 of 1
      • Once all screws are removed, use a spudger to get under a corner and unclip the hooks.
      • Once the spudger is under the cover, slide it all the way around the device, pushing lightly into the device making sure it stays under the cover until all the clips are removed.
      • The back cover is difficult to remove, so do not be afraid of using some force once all of the clips have been removed.
      Ask FixBot
    4. Kurio 10S Back Cover Replacement: step 4, image 1 of 1
      • The back cover should then be able to easily be removed from the device and you should see the battery and other internal components.
      Ask FixBot
3 other people completed this guide.
Author
with
Timothy Kramer
325 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 14
Past 30 Days: 86
All Time: 1,138
