Krups 963 Gasket Replacement
Views: 7.1K
View statistics:
Past 24 Hours:
9
Past 7 Days:
39
Past 30 Days:
169
All Time:
7,053
Comments: 7
6 comments on steps, 1 guide comment.
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: No estimate
Difficulty: Easy
Better Introduction
Improve this guide by completing or revising its introduction.
Tools
    1. Krups 963 Gasket Replacement, Removing Bottom Screws: step 1, image 1 of 1
      • Make sure the device is unplugged before continuing.
      • Use a Phillips size 2 screwdriver to remove the four 12mm screws found on the bottom of the machine.
      Ask FixBot
    2. Krups 963 Gasket Replacement: step 2, image 1 of 1
      • Remove the single black Phillips size 0 10mm length screw on the back of the machine.
      Ask FixBot
    3. Krups 963 Gasket Replacement: step 3, image 1 of 1
      • Remove the bottom cover from the machine and slide it down the power cord.
      Ask FixBot
    1. Krups 963 Gasket Replacement, Disassembling Krups 963 Top Cover: step 4, image 1 of 1
      • Remove the three 60mm Phillips size 0 screws holding the top cover on.
      Ask FixBot
    2. Krups 963 Gasket Replacement: step 5, image 1 of 1
      • Remove the top cap of the machine by turning it in a counter-clockwise motion (left hand in the picture), Check inside the water chamber, and if the silicone washer is inside, having fallen from the underside of the lid, retrieve it and reattach to the lid.
      • Remove the entire pressure valve stem that is attached to the side of the espresso machine: using a crescent wrench, turn the six-sided stem tube counter-clockwise; you'll find it best to apply the wrench as close to the wall of the espresso machine (farthest away from the right hand shown in the photo).
      Ask FixBot
    3. Krups 963 Gasket Replacement: step 6, image 1 of 1
      • Remove the grey plastic ring from the rim of the filter basket holder.
      Ask FixBot
    4. Krups 963 Gasket Replacement: step 7, image 1 of 1
      • Lift and remove the top black plastic cover from the machine.
      Ask FixBot
    1. Krups 963 Gasket Replacement, Gasket Replacement: step 8, image 1 of 1
      • Grab the gasket and pull up until it is removed from the machine.
      Ask FixBot
Wyatt Hall
866 Reputation
7 Guides authored
Cal Poly, Team 6-25, Maness Fall 2014 Member of Cal Poly, Team 6-25, Maness Fall 2014
CPSU-MANESS-F14S6G25
4 Members
84 Guides authored
1 Guide Comment
Where can I buy a gasket for the lid to the boiler cap lid?
Suzy River - Reply Share
Past 24 Hours: 9
Past 7 Days: 39
Past 30 Days: 169
All Time: 7,053
