Konica Minolta DiMAGE Z3 LCD Screen Replacement
  1. Konica Minolta DiMAGE Z3 LCD Screen Replacement, Open the battery chamber: step 1, image 1 of 2 Konica Minolta DiMAGE Z3 LCD Screen Replacement, Open the battery chamber: step 1, image 2 of 2
    • Open the battery chamber door by sliding the door to the side of the camera to release the safety catch.
    • Lift the door up to open.
    Ask FixBot
  2. Konica Minolta DiMAGE Z3 LCD Screen Replacement, Insert the batteries: step 2, image 1 of 1
    • Insert the four batteries inside of the battery chamber door.
    • Make sure the positive and negative battery terminals are in the correct position.
    Ask FixBot
  3. Konica Minolta DiMAGE Z3 LCD Screen Replacement, Remove the viewfinder cover: step 3, image 1 of 2 Konica Minolta DiMAGE Z3 LCD Screen Replacement, Remove the viewfinder cover: step 3, image 2 of 2
    • Use a screwdriver to remove the four viewfinder cover screws.
    Ask FixBot
  4. Konica Minolta DiMAGE Z3 LCD Screen Replacement, Remove viewfinder screws: step 4, image 1 of 1
    • Remove the 2 small screws under the viewfinder.
    Ask FixBot
  5. Konica Minolta DiMAGE Z3 LCD Screen Replacement, Remove the screen cover: step 5, image 1 of 1
    • Remove the screen cover by applying slight pressure at the top, then pulling the screen protector away from the camera.
    • Do not apply pressure to the surface of the LCD screen or it may be permanently damaged. If fingerprints are on the LCD monitor, gently wipe with a soft, clean, dry cloth.
    Ask FixBot
  6. Konica Minolta DiMAGE Z3 LCD Screen Replacement, Remove screws from the bottom panel: step 6, image 1 of 1
    • Remove 6 screws on the bottom panel.
    Ask FixBot
  7. Konica Minolta DiMAGE Z3 LCD Screen Replacement, Remove screw from battery chamber: step 7, image 1 of 1
    • Remove 1 screw on the outer side of the battery chamber.
    • This will be under the rubber grip.
    Ask FixBot
  8. Konica Minolta DiMAGE Z3 LCD Screen Replacement: step 8, image 1 of 1
    • Remove 1 screw inside the battery chamber.
    Ask FixBot
  9. Konica Minolta DiMAGE Z3 LCD Screen Replacement: step 9, image 1 of 1
    • Pull the wrist strap away from the front of the camera to remove it.
    • Then carefully pull the back casing apart from the camera.
    Ask FixBot
  10. Konica Minolta DiMAGE Z3 LCD Screen Replacement: step 10, image 1 of 1
    • Remove the 3 screws that attach the LCD screen to the circuit board.
    Ask FixBot
  11. Konica Minolta DiMAGE Z3 LCD Screen Replacement: step 11, image 1 of 1
    • Gently remove the LCD screen from the circuit board.
    • There will be a ribbon cable and some wires attached to the LCD screen.
    Ask FixBot
  12. Konica Minolta DiMAGE Z3 LCD Screen Replacement: step 12, image 1 of 1
    Tool used on this step:
    Buy
    • Use tweezers to carefully pull the ribbon cable from the circuit board, not from the LCD screen.
    • Peel back tape on LCD screen to reveal where the wires are attached. Use tweezers to detach the wires from the LCD screen.
    Ask FixBot
Hieu Ngo
431 Reputation
4 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 5
Past 30 Days: 24
All Time: 1,202
