Kolcraft Cloud Plus Wheel Replacement
  1. Kolcraft Cloud Plus Wheel Replacement, Wheel: step 1, image 1 of 2 Kolcraft Cloud Plus Wheel Replacement, Wheel: step 1, image 2 of 2
    • Applying too much force to the spudger can cause the spudger to bend or the hubcap to break. To avoid this, try prying the hubcap from a different angle or positioning your spudger at a different points around the hubcap.
    • Use the spaded side of the metal spudger to pry off the small black hubcap on the outside of the rear wheel.
    Ask FixBot
  2. Kolcraft Cloud Plus Wheel Replacement: step 2, image 1 of 2 Kolcraft Cloud Plus Wheel Replacement: step 2, image 2 of 2
    • Pull on the looped end of the cotter pin to remove it.
    Ask FixBot
  3. Kolcraft Cloud Plus Wheel Replacement: step 3, image 1 of 2 Kolcraft Cloud Plus Wheel Replacement: step 3, image 2 of 2
    • Remove the metal washer by sliding it off the axle.
    Ask FixBot
  4. Kolcraft Cloud Plus Wheel Replacement: step 4, image 1 of 1
    • Slide the wheel off of the axle.
    Ask FixBot
Christopher Peterson
330 Reputation
3 Guides authored
Cal Poly, Team 11-1, Forte Fall 2015 Member of Cal Poly, Team 11-1, Forte Fall 2015
CPSU-FORTE-F15S11G1
4 Members
3 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 12
Past 30 Days: 48
All Time: 5,174
