Kolcraft Cloud Plus "Free-Stand" Button Replacement
  1. Kolcraft Cloud Plus "Free-Stand" Button Replacement, "Free-Stand" Button: step 1, image 1 of 2 Kolcraft Cloud Plus "Free-Stand" Button Replacement, "Free-Stand" Button: step 1, image 2 of 2
    • Unscrew the two, 27mm Phillips #2 screws from the back of the “Free-Stand” button case.
    • You may want to flip the stroller over to access the screws.
    Ask FixBot
  2. Kolcraft Cloud Plus "Free-Stand" Button Replacement: step 2, image 1 of 1
    • Remove the back cover of the case by lifting it straight up.
    Ask FixBot
  3. Kolcraft Cloud Plus "Free-Stand" Button Replacement: step 3, image 1 of 1
    • The spring may pop out while removing the "Free Stand" button, so lift the button slowly to avoid losing the spring.
    • To access the spring, remove the red, "Free-Stand" button by lifting it straight up.
    Ask FixBot
  4. Kolcraft Cloud Plus "Free-Stand" Button Replacement: step 4, image 1 of 1
    • If the spring does not come out when you remove the "Free-Stand" button, lift the spring out of the case so it can be fixed or replaced.
    Ask FixBot
Christopher Peterson
330 Reputation
3 Guides authored
Cal Poly, Team 11-1, Forte Fall 2015 Member of Cal Poly, Team 11-1, Forte Fall 2015
CPSU-FORTE-F15S11G1
4 Members
3 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 43
All Time: 2,000
