Up to 20% off select tools
Kodak Signet 35 Shutter Spring Replacement
Views: 3.9K
View statistics:
Past 24 Hours:
3
Past 7 Days:
26
Past 30 Days:
127
All Time:
3,937
Comments: 3
3 guide comments.
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 7 minutes
Difficulty: Difficult
Tools
Introduction
Go to step 1 ↓
If the shutter on your Kodak Signet 35 isn't working properly, then the shutter spring may need to be cleaned or replaced. This guide will show you how. Please make sure you have all the necessary tools, as well as a clean and stable surface on which to work, before you start these steps.
    1. Kodak Signet 35 Shutter Spring Replacement, Shutter Spring: step 1, image 1 of 3 Kodak Signet 35 Shutter Spring Replacement, Shutter Spring: step 1, image 2 of 3 Kodak Signet 35 Shutter Spring Replacement, Shutter Spring: step 1, image 3 of 3
      • While the camera is lying on its back, unscrew the front lens assembly and remove the lens and the faceplate. Then lift off the speed setting.
      Ask FixBot
    2. Kodak Signet 35 Shutter Spring Replacement: step 2, image 1 of 2 Kodak Signet 35 Shutter Spring Replacement: step 2, image 2 of 2
      • Remove the lever from the stopper by pushing it back and then upwards.
      Ask FixBot
    3. Kodak Signet 35 Shutter Spring Replacement: step 3, image 1 of 2 Kodak Signet 35 Shutter Spring Replacement: step 3, image 2 of 2
      Tool used on this step:
      Buy
      • Remove the stopper by lifting it upwards with the tweezers.
      Ask FixBot
    4. Kodak Signet 35 Shutter Spring Replacement: step 4, image 1 of 3 Kodak Signet 35 Shutter Spring Replacement: step 4, image 2 of 3 Kodak Signet 35 Shutter Spring Replacement: step 4, image 3 of 3
      • Using tweezers, unhitch the spring from the base and remove it by lifting upwards.
      Ask FixBot
Author
with
Mellyssa Greene
134 Reputation
1 Guide authored
USF Tampa, Team 6-3, Remmell Fall 2016 Member of USF Tampa, Team 6-3, Remmell Fall 2016
USFT-REMMELL-F16S6G3
4 Members
60 Guides authored
3 Guide Comments
What kind of spring can be used to replace it or how would one revitalize the old spring?
Ben Le - Reply Share
What does “front lens assembly” look like? what parts do I have to unscrew?
Shawn Reynolds - Reply Share
The part that needs to be unscrewed is the silver collar right around the black lens element. This instructable could do with another photo showing this.
Eben F - Reply Share
Past 24 Hours: 3
Past 7 Days: 26
Past 30 Days: 127
All Time: 3,937
