Kodak S100 EF Lens Replacement
Views: 2.8K
View statistics:
Past 24 Hours:
2
Past 7 Days:
23
Past 30 Days:
100
All Time:
2,758
Comments: 0
Go to guide comments
Completed: 0
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 30 minutes
Difficulty: Difficult
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Introduction
Go to step 1 ↓
You need the right equipment, like a clean or unbroken lens, to take a flawless photo. A spotless or undamaged lens is essential for capturing a flawless photograph. This guide will show you how to replace a Kodak S100 EF lens to improve your photos or repair any broken lens. The lens brings in light to the camera, resulting in a more focused image. If your lens needs to be replaced, the graphics in your photographs will appear spotty or blurry. When replacing the lens, you must exercise caution due to the presence of high voltages.
Tools
    1. Kodak S100 EF Lens Replacement, Front Cover: step 1, image 1 of 1
      • Have the camera facing upwards and the flash closest to you.
      • Unscrew the two 6.2 mm Phillips screws on the top half of the camera.
      Ask FixBot
    2. Kodak S100 EF Lens Replacement: step 2, image 1 of 1
      • Flip the camera over to the other side-with flash farthest from you.
      • Unscrew top two 6.2mm Phillips screws on this side.
      Ask FixBot
    3. Kodak S100 EF Lens Replacement: step 3, image 1 of 1
      • Turn the camera so the bottom is facing up with the front-facing away.
      • Unscrew the 6.2mm Phillips screw on the top right.
      • The front cover is now unscrewed and should be lifted evenly and removed.
      Ask FixBot
    1. Kodak S100 EF Lens Replacement, Lens: step 4, image 1 of 1
      • Remove the two 6.2mm Phillips screws on either side of the lens securing the metal plate.
      Ask FixBot
    2. Kodak S100 EF Lens Replacement: step 5, image 1 of 1
      • Pull aside the plastic piece resting atop the metal lens plate in order to access the other screws.
      Ask FixBot
    3. Kodak S100 EF Lens Replacement: step 6, image 1 of 1
      • To remove other screws, metal panel must be lifted up slightly to access.
      • Lift metal panel and insert screwdriver through holes in panel to reach screws underneath. Remove the two 6.2mm Phillips screws.
      Ask FixBot
    4. Kodak S100 EF Lens Replacement: step 7, image 1 of 1
      • Look at the black plate on the right side of the lens that the metal plate is resting on.
      • Unscrew two 6.2mm Phillips screws on the black plate next to the lens.
      • At this point, all screws are removed and lens can should be carefully lifted and removed, including both plates and the plastic ring around the lens.
      Ask FixBot
Michelle
131 Reputation
5 Guides authored
Cal Poly, Team 25-28, Garner Spring 2011 Member of Cal Poly, Team 25-28, Garner Spring 2011
CPSU-GARNER-S11S25G28
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 23
Past 30 Days: 100
All Time: 2,758
