Kodak S100 EF Front Cover Replacement
Views: 2.7K
View statistics:
Past 24 Hours:
Past 7 Days:
20
Past 30 Days:
93
All Time:
2,701
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 minutes
Difficulty: Easy
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Introduction
Go to step 1 ↓
Use this guide to replace the front cover.
Tools
    1. Kodak S100 EF Front Cover Replacement, Front Cover: step 1, image 1 of 1
      • Have the camera facing upwards and the flash closest to you.
      • Unscrew the two 6.2 mm Phillips screws on the top half of the camera.
      Ask FixBot
    2. Kodak S100 EF Front Cover Replacement: step 2, image 1 of 1
      • Flip the camera over to the other side-with flash farthest from you.
      • Unscrew top two 6.2mm Phillips screws on this side.
      Ask FixBot
    3. Kodak S100 EF Front Cover Replacement: step 3, image 1 of 1
      • Turn the camera so the bottom is facing up with the front-facing away.
      • Unscrew the 6.2mm Phillips screw on the top right.
      • The front cover is now unscrewed and should be lifted evenly and removed.
      Ask FixBot
Michelle
131 Reputation
5 Guides authored
Cal Poly, Team 25-28, Garner Spring 2011 Member of Cal Poly, Team 25-28, Garner Spring 2011
CPSU-GARNER-S11S25G28
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 20
Past 30 Days: 93
All Time: 2,701
