Kodak S100 EF Flash Capacitor Replacement
  1. Kodak S100 EF Flash Capacitor Replacement, Back Cover: step 1, image 1 of 2 Kodak S100 EF Flash Capacitor Replacement, Back Cover: step 1, image 2 of 2
    • Remove the two 6.2mm Phillips screws on both sides of camera's back cover.
    Ask FixBot
  2. Kodak S100 EF Flash Capacitor Replacement: step 2, image 1 of 1
    • Turn camera so the bottom is facing up and the front is facing away.
    • Remove the two 6.2mm Phillips screws on the bottom back cover of the camera.
    • Back cover is now unscrewed an can be removed.
    Ask FixBot
  3. Kodak S100 EF Flash Capacitor Replacement: step 3, image 1 of 1
    • Have the back of the camera facing up.
    • Unscrew the 6.2mm Phillips screw next to the viewfinder.
    • The back cover is now unscrewed. Lift up and pull the cover off evenly.
    Ask FixBot
  4. Kodak S100 EF Flash Capacitor Replacement, Flash Capacitor: step 4, image 1 of 1
    • The capacitor is located at the bottom center of the camera.
    Ask FixBot
  5. Kodak S100 EF Flash Capacitor Replacement: step 5, image 1 of 1
    Ask FixBot
Michelle
131 Reputation
5 Guides authored
Cal Poly, Team 25-28, Garner Spring 2011 Member of Cal Poly, Team 25-28, Garner Spring 2011
CPSU-GARNER-S11S25G28
4 Members
6 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 34
All Time: 2,965
