Kodak PixPro AZ251 Shutter Button Replacement
Views: 1.5K
View statistics:
Past 24 Hours:
2
Past 7 Days:
16
Past 30 Days:
71
All Time:
1,539
Comments: 3
3 comments on steps.
Completed: 0
Favorites: 0
Time Required: 30 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
In this guide, you will learn how to repair and replace a loose or faulty shutter button on your Kodak PixPro AZ251.
Tools
    1. Kodak PixPro AZ251 Shutter Button Replacement, Batteries: step 1, image 1 of 2 Kodak PixPro AZ251 Shutter Button Replacement, Batteries: step 1, image 2 of 2
      • Slide switch to open lock position.
      Ask FixBot
    2. Kodak PixPro AZ251 Shutter Button Replacement: step 2, image 1 of 2 Kodak PixPro AZ251 Shutter Button Replacement: step 2, image 2 of 2
      • Press down on the battery cover and slide outwards to open.
      Ask FixBot
    3. Kodak PixPro AZ251 Shutter Button Replacement: step 3, image 1 of 1
      • Remove the batteries.
      Ask FixBot
    1. Kodak PixPro AZ251 Shutter Button Replacement, Back Cover: step 4, image 1 of 3 Kodak PixPro AZ251 Shutter Button Replacement, Back Cover: step 4, image 2 of 3 Kodak PixPro AZ251 Shutter Button Replacement, Back Cover: step 4, image 3 of 3
      • Remove a total of four 5mm JIS #000 screws from around the camera:
      • Two screws from the right side.
      • Two screws from the left side.
      Ask FixBot
    2. Kodak PixPro AZ251 Shutter Button Replacement: step 5, image 1 of 1
      • Remove the single 5mm Phillips #00 screw from the bottom.
      Ask FixBot
    3. Kodak PixPro AZ251 Shutter Button Replacement: step 6, image 1 of 2 Kodak PixPro AZ251 Shutter Button Replacement: step 6, image 2 of 2
      • Open the flash module.
      • Remove the two 6mm JIS #00 screws found inside of the flash housing.
      Ask FixBot
    4. Kodak PixPro AZ251 Shutter Button Replacement: step 7, image 1 of 3 Kodak PixPro AZ251 Shutter Button Replacement: step 7, image 2 of 3 Kodak PixPro AZ251 Shutter Button Replacement: step 7, image 3 of 3
      • Use a plastic opening tool to pry apart both halves of the camera.
      • Remove the back panel.
      Ask FixBot
    1. Kodak PixPro AZ251 Shutter Button Replacement, LCD Screen: step 8, image 1 of 2 Kodak PixPro AZ251 Shutter Button Replacement, LCD Screen: step 8, image 2 of 2
      • Remove these three JIS #000 screws from the control board:
      • 5mm screw.
      • 4mm screw.
      • 2mm screw.
      Ask FixBot
    2. Kodak PixPro AZ251 Shutter Button Replacement: step 9, image 1 of 1
      • Pull the small metal switch plate to the side.
      Ask FixBot
    3. Kodak PixPro AZ251 Shutter Button Replacement: step 10, image 1 of 2 Kodak PixPro AZ251 Shutter Button Replacement: step 10, image 2 of 2
      • Pry the LCD screen out of the metal housing plate with a plastic opening tool.
      Ask FixBot
    4. Kodak PixPro AZ251 Shutter Button Replacement: step 11, image 1 of 2 Kodak PixPro AZ251 Shutter Button Replacement: step 11, image 2 of 2
      • Use a spudger to flip up the retaining flap on the display ribbon cable ZIF socket.
      • Pull the orange cable out of the socket.
      Ask FixBot
    1. Kodak PixPro AZ251 Shutter Button Replacement, Shutter Button: step 12, image 1 of 2 Kodak PixPro AZ251 Shutter Button Replacement, Shutter Button: step 12, image 2 of 2
      • Remove one 4mm JIS #000 screw from the top of the camera.
      Ask FixBot
    2. Kodak PixPro AZ251 Shutter Button Replacement: step 13, image 1 of 2 Kodak PixPro AZ251 Shutter Button Replacement: step 13, image 2 of 2
      Tool used on this step:
      Buy
      • Using tweezers, disconnect the orange cable connection at the top of the motherboard.
      Ask FixBot
    3. Kodak PixPro AZ251 Shutter Button Replacement: step 14, image 1 of 2 Kodak PixPro AZ251 Shutter Button Replacement: step 14, image 2 of 2
      • Pull the mode dial up and off of the camera.
      • Rotate carefully to avoid breaking the screw attaching the top side cover to the main body of the camera.
      Ask FixBot
    4. Kodak PixPro AZ251 Shutter Button Replacement: step 15, image 1 of 2 Kodak PixPro AZ251 Shutter Button Replacement: step 15, image 2 of 2
      • Turn camera upside down.
      • Remove the six 2mm JIS #000 screws from the metal base of the shutter button.
      Ask FixBot
    5. Kodak PixPro AZ251 Shutter Button Replacement: step 16, image 1 of 2 Kodak PixPro AZ251 Shutter Button Replacement: step 16, image 2 of 2
      • Remove the metal base and ribbon cables.
      Ask FixBot
    6. Kodak PixPro AZ251 Shutter Button Replacement: step 17, image 1 of 1
      • While holding the shutter button in place, remove the two 4mm JIS #000 screws from the base.
      Ask FixBot
    7. Kodak PixPro AZ251 Shutter Button Replacement: step 18, image 1 of 1
      • Remove the plastic base of the shutter button using tweezers by pulling it straight upward.
      Ask FixBot
    8. Kodak PixPro AZ251 Shutter Button Replacement: step 19, image 1 of 1
      • Remove the shutter button by pulling it out from the bottom side of the top cover.
      Ask FixBot
Rachel Llewellyn
509 Reputation
3 Guides authored
USF Tampa, Team S1-G1, Cagle Spring 2018 Member of USF Tampa, Team S1-G1, Cagle Spring 2018
USFT-CAGLE-S18S1G1
4 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 16
Past 30 Days: 71
All Time: 1,539
