Kodak PixPro AZ251 Motherboard Replacement
  1. Kodak PixPro AZ251 Motherboard Replacement, Batteries: step 1, image 1 of 2 Kodak PixPro AZ251 Motherboard Replacement, Batteries: step 1, image 2 of 2
    • Slide switch to open lock position.
    Ask FixBot
  2. Kodak PixPro AZ251 Motherboard Replacement: step 2, image 1 of 2 Kodak PixPro AZ251 Motherboard Replacement: step 2, image 2 of 2
    • Press down on the battery cover and slide outwards to open.
    Ask FixBot
  3. Kodak PixPro AZ251 Motherboard Replacement: step 3, image 1 of 1
    • Remove the batteries.
    Ask FixBot
  4. Kodak PixPro AZ251 Motherboard Replacement, Back Cover: step 4, image 1 of 3 Kodak PixPro AZ251 Motherboard Replacement, Back Cover: step 4, image 2 of 3 Kodak PixPro AZ251 Motherboard Replacement, Back Cover: step 4, image 3 of 3
    • Remove a total of four 5mm JIS #000 screws from around the camera:
    • Two screws from the right side.
    • Two screws from the left side.
    Ask FixBot
  5. Kodak PixPro AZ251 Motherboard Replacement: step 5, image 1 of 1
    • Remove the single 5mm Phillips #00 screw from the bottom.
    Ask FixBot
  6. Kodak PixPro AZ251 Motherboard Replacement: step 6, image 1 of 2 Kodak PixPro AZ251 Motherboard Replacement: step 6, image 2 of 2
    • Open the flash module.
    • Remove the two 6mm JIS #00 screws found inside of the flash housing.
    Ask FixBot
  7. Kodak PixPro AZ251 Motherboard Replacement: step 7, image 1 of 3 Kodak PixPro AZ251 Motherboard Replacement: step 7, image 2 of 3 Kodak PixPro AZ251 Motherboard Replacement: step 7, image 3 of 3
    • Use a plastic opening tool to pry apart both halves of the camera.
    • Remove the back panel.
    Ask FixBot
  8. Kodak PixPro AZ251 Motherboard Replacement, LCD Screen: step 8, image 1 of 2 Kodak PixPro AZ251 Motherboard Replacement, LCD Screen: step 8, image 2 of 2
    • Remove these three JIS #000 screws from the control board:
    • 5mm screw.
    • 4mm screw.
    • 2mm screw.
    Ask FixBot
  9. Kodak PixPro AZ251 Motherboard Replacement: step 9, image 1 of 1
    • Pull the small metal switch plate to the side.
    Ask FixBot
  10. Kodak PixPro AZ251 Motherboard Replacement: step 10, image 1 of 2 Kodak PixPro AZ251 Motherboard Replacement: step 10, image 2 of 2
    • Pry the LCD screen out of the metal housing plate with a plastic opening tool.
    Ask FixBot
  11. Kodak PixPro AZ251 Motherboard Replacement: step 11, image 1 of 2 Kodak PixPro AZ251 Motherboard Replacement: step 11, image 2 of 2
    • Use a spudger to flip up the retaining flap on the display ribbon cable ZIF socket.
    • Pull the orange cable out of the socket.
    Ask FixBot
  12. Kodak PixPro AZ251 Motherboard Replacement, Motherboard: step 12, image 1 of 2 Kodak PixPro AZ251 Motherboard Replacement, Motherboard: step 12, image 2 of 2
    • Remove three 4mm JIS #000 screws from the metal housing plate.
    Ask FixBot
  13. Kodak PixPro AZ251 Motherboard Replacement: step 13, image 1 of 1
    • Lift the metal housing plate out using your hands.
    Ask FixBot
  14. Kodak PixPro AZ251 Motherboard Replacement: step 14, image 1 of 1
    Tool used on this step:
    Buy
    • Disconnect the orange cable, connecting the small metal switch plate to the motherboard, by pulling it outwards with tweezers.
    Ask FixBot
  15. Kodak PixPro AZ251 Motherboard Replacement: step 15, image 1 of 2 Kodak PixPro AZ251 Motherboard Replacement: step 15, image 2 of 2
    • Disconnect two orange cables, one at the top and the other at the bottom of the motherboard, by pulling them outwards with tweezers.
    • Use a spudger to flip up the retaining flap on the ribbon cable ZIF socket.
    Ask FixBot
  16. Kodak PixPro AZ251 Motherboard Replacement: step 16, image 1 of 2 Kodak PixPro AZ251 Motherboard Replacement: step 16, image 2 of 2
    • Remove the rectangular black cushion pad on the bottom left of the motherboard by pulling it upwards with your hands.
    • Disconnect the orange cable by pulling it outwards with tweezers.
    Ask FixBot
  17. Kodak PixPro AZ251 Motherboard Replacement: step 17, image 1 of 1
    • Remove the two 4mm JIS #000 screws from the motherboard.
    Ask FixBot
  18. Kodak PixPro AZ251 Motherboard Replacement: step 18, image 1 of 1
    • Desolder two pairs of electrical cable connections on the top left of the motherboard using the soldering iron.
    • Desolder the metal connector joining the two parts of the motherboard using the soldering iron.
    • The unsoldering steps are not shown.
    Ask FixBot
  19. Kodak PixPro AZ251 Motherboard Replacement: step 19, image 1 of 1
    • Lift the motherboard up using your hands.
    Ask FixBot
5 other people completed this guide.
Deborah Oliveira
319 Reputation
2 Guides authored
USF Tampa, Team S1-G1, Cagle Spring 2018 Member of USF Tampa, Team S1-G1, Cagle Spring 2018
USFT-CAGLE-S18S1G1
4 Members
7 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 84
All Time: 2,361
