Kodak PixPro AZ251 Back Cover Replacement
Views: 1.4K
View statistics:
Past 24 Hours:
2
Past 7 Days:
9
Past 30 Days:
69
All Time:
1,368
Comments: 1
1 comment on steps.
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
Removing the back cover of your Kodak PixPro AZ251 gives you access to the camera's LCD screen and motherboard. This guide will instruct you on how to remove the back cover of your Kodak PixPro AZ251.
Tools
    1. Kodak PixPro AZ251 Back Cover Replacement, Batteries: step 1, image 1 of 2 Kodak PixPro AZ251 Back Cover Replacement, Batteries: step 1, image 2 of 2
      • Slide switch to open lock position.
      Ask FixBot
    2. Kodak PixPro AZ251 Back Cover Replacement: step 2, image 1 of 2 Kodak PixPro AZ251 Back Cover Replacement: step 2, image 2 of 2
      • Press down on the battery cover and slide outwards to open.
      Ask FixBot
    3. Kodak PixPro AZ251 Back Cover Replacement: step 3, image 1 of 1
      • Remove the batteries.
      Ask FixBot
    1. Kodak PixPro AZ251 Back Cover Replacement, Back Cover: step 4, image 1 of 3 Kodak PixPro AZ251 Back Cover Replacement, Back Cover: step 4, image 2 of 3 Kodak PixPro AZ251 Back Cover Replacement, Back Cover: step 4, image 3 of 3
      • Remove a total of four 5mm JIS #000 screws from around the camera:
      • Two screws from the right side.
      • Two screws from the left side.
      Ask FixBot
    2. Kodak PixPro AZ251 Back Cover Replacement: step 5, image 1 of 1
      • Remove the single 5mm Phillips #00 screw from the bottom.
      Ask FixBot
    3. Kodak PixPro AZ251 Back Cover Replacement: step 6, image 1 of 2 Kodak PixPro AZ251 Back Cover Replacement: step 6, image 2 of 2
      • Open the flash module.
      • Remove the two 6mm JIS #00 screws found inside of the flash housing.
      Ask FixBot
    4. Kodak PixPro AZ251 Back Cover Replacement: step 7, image 1 of 3 Kodak PixPro AZ251 Back Cover Replacement: step 7, image 2 of 3 Kodak PixPro AZ251 Back Cover Replacement: step 7, image 3 of 3
      • Use a plastic opening tool to pry apart both halves of the camera.
      • Remove the back panel.
      Ask FixBot
Luiza Oliveira
298 Reputation
2 Guides authored
USF Tampa, Team S1-G1, Cagle Spring 2018 Member of USF Tampa, Team S1-G1, Cagle Spring 2018
USFT-CAGLE-S18S1G1
4 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 9
Past 30 Days: 69
All Time: 1,368
