Kodak PIXPRO WPZ2 SD Card Replacement
Views: 1.1K
View statistics:
Past 24 Hours:
4
Past 7 Days:
24
Past 30 Days:
176
All Time:
1,065
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 1 minute
Difficulty: Very easy
Better Introduction
Improve this guide by completing or revising its introduction.
Introduction
Go to step 1 ↓
An SD card is a removable flash memory card used in cameras to store photos and videos.
Before You Start:
Correct Card Types:  Either use a microSD or microSDHC make sure not to use a microSDXC or standard SD.
Max Size Allowed: 32 GB.
Power Off: Make sure to turn the camera OFF before removing or inserting any sort of card to avoid damage.
    1. Kodak PIXPRO WPZ2 SD Card Replacement, SD Card: step 1, image 1 of 3 Kodak PIXPRO WPZ2 SD Card Replacement, SD Card: step 1, image 2 of 3 Kodak PIXPRO WPZ2 SD Card Replacement, SD Card: step 1, image 3 of 3
      • Make sure to turn the camera OFF before removing or inserting the SD card to avoid damage.
      • Flip the camera so the bottom is facing up.
      • Slide the lock switch on the battery/memory card door to the unlocked position.
      • The latch door should pop open once the lock is released.
      Ask FixBot
    2. Kodak PIXPRO WPZ2 SD Card Replacement: step 2, image 1 of 3 Kodak PIXPRO WPZ2 SD Card Replacement: step 2, image 2 of 3 Kodak PIXPRO WPZ2 SD Card Replacement: step 2, image 3 of 3
      • Gently push down on the microSD card until you feel a click.
      • The card should release from its socket and pop up a couple of millimeters.
      • Pull the microSD out.
      • Check the camera to ensure there are no error messages. If the card is correctly inserted and compatible, you should not see one. Take one test picture to make sure the card is saving your new images.
      Ask FixBot
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Victor Pleva
85 Reputation
1 Guide authored
Texas Tech, Team 37-4, Allen Fall 2025 Member of Texas Tech, Team 37-4, Allen Fall 2025
TTU-ALLEN-F25S37G4
4 Members
48 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 24
Past 30 Days: 176
All Time: 1,065
