Up to 20% off select tools
Kodak PIXPRO WPZ2 Button Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
12
Past 30 Days:
81
All Time:
548
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 - 20 minutes
Difficulty: Moderate
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Markup Mishap
This guide needs better markups. Help out by correcting or making some markup annotations.
Needs More Images
A few more images would make this guide's procedures crystal clear.
Better Introduction
Improve this guide by completing or revising its introduction.
Tools
  • T5 Torx Screwdriver
    4.9
  • Spudger
    4.9
    1. Kodak PIXPRO WPZ2 Button Replacement, Battery: step 1, image 1 of 3 Kodak PIXPRO WPZ2 Button Replacement, Battery: step 1, image 2 of 3 Kodak PIXPRO WPZ2 Button Replacement, Battery: step 1, image 3 of 3
      • Turn the camera upside down to locate the battery compartment.
      • Slide the battery door latch to the unlock position.
      • The door should spring open.
      • Lift the door open to access the battery compartment.
      Ask FixBot
    2. Kodak PIXPRO WPZ2 Button Replacement: step 2, image 1 of 1
      • Push the yellow release lever beside the battery compartment to the side.
      • The battery will spring up slightly.
      • Pull the battery from the compartment.
      • Place the new battery into the compartment with the metal contacts facing the metal connectors inside. Push the battery down until it clicks under the release lever. Close the battery door and slide the latch to lock it.
      Ask FixBot
    1. Kodak PIXPRO WPZ2 Button Replacement, Power and Shutter Button replacement: step 3, image 1 of 2 Kodak PIXPRO WPZ2 Button Replacement, Power and Shutter Button replacement: step 3, image 2 of 2
      • Use a Torx T5 screwdriver to remove the four screws securing the button panel.
      • Use a spudger to gently pry the button panel off the camera.
      Ask FixBot
    2. Kodak PIXPRO WPZ2 Button Replacement: step 4, image 1 of 1
      • Lift the silicone pad to remove the power and shutter buttons.
      Ask FixBot
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Author
with
Addison Anderson
303 Reputation
1 Guide authored
Texas Tech, Team 37-4, Allen Fall 2025 Member of Texas Tech, Team 37-4, Allen Fall 2025
TTU-ALLEN-F25S37G4
4 Members
48 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 12
Past 30 Days: 81
All Time: 548
