Introduction
If your Kodak PIXPRO WPZ2 camera doesn’t power on or holds a charge for only a short time, the battery may need to be replaced. This guide will show how to remove and replace the rechargeable Li-Ion battery safely.
You will not need any tools for this process, but ensure the camera is turned off before you begin the replacement.
Turn the camera upside down to locate the battery compartment.
Slide the battery door latch to the unlock position.
Lift the door open to access the battery compartment.
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
