Kodak Easyshare Z981 Top Shutter Button Replacement
    1. Kodak Easyshare Z981 Top Shutter Button Replacement, Top Shutter Button: step 1, image 1 of 2 Kodak Easyshare Z981 Top Shutter Button Replacement, Top Shutter Button: step 1, image 2 of 2
      • Open the battery cover and remove the AA batteries from the camera if any are inserted.
      Ask FixBot
    2. Kodak Easyshare Z981 Top Shutter Button Replacement: step 2, image 1 of 2 Kodak Easyshare Z981 Top Shutter Button Replacement: step 2, image 2 of 2
      Tool used on this step:
      Phillips #00 Screwdriver
      $5.49
      Buy
      • Remove all screws on the outside of the camera with a 00 Phillips-Head screwdriver
      • Eight (8) 3mm screws on the lower portion of the camera
      • Four (4) screws on the bottom of the camera
      • Four (4) screws inside the battery cover
      Ask FixBot
    3. Kodak Easyshare Z981 Top Shutter Button Replacement: step 3, image 1 of 3 Kodak Easyshare Z981 Top Shutter Button Replacement: step 3, image 2 of 3 Kodak Easyshare Z981 Top Shutter Button Replacement: step 3, image 3 of 3
      • Detach the bottom part of the camera by removing four (4) 3mm screws
      • Two (2) screws are located in the left side of the device
      • Two (2) screws are locatecd in the right side of the device
      Ask FixBot
    4. Kodak Easyshare Z981 Top Shutter Button Replacement: step 4, image 1 of 2 Kodak Easyshare Z981 Top Shutter Button Replacement: step 4, image 2 of 2
      • Use the Plastic Opening Tool to put light pressure and remove the back cover of the camera
      • Be gentle when removing the back cover
      Ask FixBot
    5. Kodak Easyshare Z981 Top Shutter Button Replacement: step 5, image 1 of 3 Kodak Easyshare Z981 Top Shutter Button Replacement: step 5, image 2 of 3 Kodak Easyshare Z981 Top Shutter Button Replacement: step 5, image 3 of 3
      Buy
      • Unscrew the four (4) 3mm screws to remove the screen from the circuit board
      • Use Tweezers to delicately detach the ribbon cable
      • Carefully remove the screen brace from the circuit board
      Ask FixBot
    6. Kodak Easyshare Z981 Top Shutter Button Replacement: step 6, image 1 of 3 Kodak Easyshare Z981 Top Shutter Button Replacement: step 6, image 2 of 3 Kodak Easyshare Z981 Top Shutter Button Replacement: step 6, image 3 of 3
      • Remove the two (2) 3mm screws from inside flash compartment
      • Remove one (1) 3mm screw from the circuit board
      Ask FixBot
    7. Kodak Easyshare Z981 Top Shutter Button Replacement: step 7, image 1 of 2 Kodak Easyshare Z981 Top Shutter Button Replacement: step 7, image 2 of 2
      Buy
      • Use the Tweezers to detach the ribbon cable connecter from the circuit board
      • Use the Plastic Opening Tool to gently apply pressure on the top of the camera and remove the upper portion
      Ask FixBot
    8. Kodak Easyshare Z981 Top Shutter Button Replacement: step 8, image 1 of 3 Kodak Easyshare Z981 Top Shutter Button Replacement: step 8, image 2 of 3 Kodak Easyshare Z981 Top Shutter Button Replacement: step 8, image 3 of 3
      • Remove the four (4) 3mm screws from the circuit board directly underneath the shutter button and gently move the circuit board aside
      • Lift up the metal clamp
      • Use caution when removing the circuit board to avoid tearing the wires connected
      Ask FixBot
    9. Kodak Easyshare Z981 Top Shutter Button Replacement: step 9, image 1 of 3 Kodak Easyshare Z981 Top Shutter Button Replacement: step 9, image 2 of 3 Kodak Easyshare Z981 Top Shutter Button Replacement: step 9, image 3 of 3
      Buy
      • Pull the small brace on top of the shutter button
      • Using the Tweezers, gently remove the shutter button
      Ask FixBot
Matthew Myers
219 Reputation
1 Guide authored
1 Guide Comment
looking for z981 bottom wrist grip jwkcm1978@hotmail.com
jwkcm1978 - Reply Share
Past 24 Hours: 7
Past 7 Days: 20
Past 30 Days: 37
All Time: 1,053
