Kodak Easyshare Z981 LCD Screen Replacement
  1. Kodak Easyshare Z981 LCD Screen Replacement, LCD Screen: step 1, image 1 of 2 Kodak Easyshare Z981 LCD Screen Replacement, LCD Screen: step 1, image 2 of 2
    • Open the battery cover and remove batteries from the camera if any are inserted.
    Ask FixBot
  2. Kodak Easyshare Z981 LCD Screen Replacement: step 2, image 1 of 2 Kodak Easyshare Z981 LCD Screen Replacement: step 2, image 2 of 2
    Tool used on this step:
    Phillips #00 Screwdriver
    $5.49
    Buy
    • Use a 00 Phillips-Head screwdriver to remove screws:
    • Remove the 3 mm screws from the camera
    • Four (4) screws are in the bottom of the device
    • Four (4) screws are inside the battery cover
    Ask FixBot
  3. Kodak Easyshare Z981 LCD Screen Replacement: step 3, image 1 of 1
    • Start from a corner and gently remove the cover.
    • The cover will easily lift off, so not much pressure is required.
    • Make sure to gently remove the bottom cover in order to avoid breaking the plastic.
    Ask FixBot
  4. Kodak Easyshare Z981 LCD Screen Replacement: step 4, image 1 of 2 Kodak Easyshare Z981 LCD Screen Replacement: step 4, image 2 of 2
    $5.49
    Buy
    • Use a Phillips #00 Screwdriver to remove the 4 mm screws from each side of the back cover of the camera.
    • Two (2) screws are located in the left side of the device
    • Two (2) screws are locatecd in the right side of the device
    Ask FixBot
  5. Kodak Easyshare Z981 LCD Screen Replacement: step 5, image 1 of 2 Kodak Easyshare Z981 LCD Screen Replacement: step 5, image 2 of 2
    • Insert the Plastic Opening Tool in to the crevices of back cover and gently apply pressure
    • Be gentle while removing the cover, to avoid cracking the case
    Ask FixBot
  6. Kodak Easyshare Z981 LCD Screen Replacement: step 6, image 1 of 2 Kodak Easyshare Z981 LCD Screen Replacement: step 6, image 2 of 2
    • Once the back cover is removed locate the four 3mm screws holding the screen and the metal brace to the circuit board
    Ask FixBot
  7. Kodak Easyshare Z981 LCD Screen Replacement: step 7, image 1 of 3 Kodak Easyshare Z981 LCD Screen Replacement: step 7, image 2 of 3 Kodak Easyshare Z981 LCD Screen Replacement: step 7, image 3 of 3
    • Gently lift up the metal brace and use a pair of tweezers to disconnect the ribbon cable connector.
    • Remove the screen brace from the circuit board.
    • Use extreme caution when removing the LCD brace; pulling the brace may tear the cable.
    Ask FixBot
Daniel Ramirez
152 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 17
All Time: 965
