Kodak Easyshare Z981 Back Cover Replacement
  1. Kodak Easyshare Z981 Back Cover Replacement, Back Cover: step 1, image 1 of 3 Kodak Easyshare Z981 Back Cover Replacement, Back Cover: step 1, image 2 of 3 Kodak Easyshare Z981 Back Cover Replacement, Back Cover: step 1, image 3 of 3
    Tool used on this step:
    Phillips #00 Screwdriver
    $5.49
    Buy
    • Remove screws using a 00 Phillips-Head screwdriver:
    • Eight (8) 3mm screws on the lower portion of the camera
    • Four (4) on the bottom of the camera
    • Four (4) inside the battery cover
    Ask FixBot
  2. Kodak Easyshare Z981 Back Cover Replacement: step 2, image 1 of 1
    • Start from a corner and gently remove the bottom cover of the camera.
    • The cover will easily lift off without much pressure necessary.
    Ask FixBot
  3. Kodak Easyshare Z981 Back Cover Replacement: step 3, image 1 of 2 Kodak Easyshare Z981 Back Cover Replacement: step 3, image 2 of 2
    $5.49
    Buy
    • Use a Phillips #00 Screwdriver to remove the 4 mm screws from each side of the back cover of the camera.
    • Two (2) screws are located in the left side of the device
    • Two (2) screws are locatecd in the right side of the device
    Ask FixBot
  4. Kodak Easyshare Z981 Back Cover Replacement: step 4, image 1 of 2 Kodak Easyshare Z981 Back Cover Replacement: step 4, image 2 of 2
    • Use a Plastic Opening Tool to remove the back of the camera and pull gently on the cover to remove the cover
    • Start from one corner and apply light pressure with the tool.
    Ask FixBot
Olivia Boyna
509 Reputation
3 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 29
All Time: 1,066
