Kodak Easyshare V1003 LCD Display Replacement
    1. Kodak Easyshare V1003  LCD Display Replacement, Battery: step 1, image 1 of 1
      • Turn off camera by firmly pressing the power button that is located on the top of the camera.
      Ask FixBot
    2. Kodak Easyshare V1003  LCD Display Replacement: step 2, image 1 of 1
      • Position camera with the bottom facing up.
      Ask FixBot
    3. Kodak Easyshare V1003  LCD Display Replacement: step 3, image 1 of 1
      • With your finger, slide the battery cover in the direction of the open arrow.
      Ask FixBot
    4. Kodak Easyshare V1003  LCD Display Replacement: step 4, image 1 of 1
      • Lift the battery cover up gently.
      Ask FixBot
    5. Kodak Easyshare V1003  LCD Display Replacement: step 5, image 1 of 2 Kodak Easyshare V1003  LCD Display Replacement: step 5, image 2 of 2
      • Gently push the battery down until a click is heard. Battery should release and be lifted out of slot.
      Ask FixBot
    1. Kodak Easyshare V1003  LCD Display Replacement, Buttons: step 6, image 1 of 3 Kodak Easyshare V1003  LCD Display Replacement, Buttons: step 6, image 2 of 3 Kodak Easyshare V1003  LCD Display Replacement, Buttons: step 6, image 3 of 3
      • Use a J00 screwdriver to remove the five exterior screws.
      Ask FixBot
    2. Kodak Easyshare V1003  LCD Display Replacement: step 7, image 1 of 3 Kodak Easyshare V1003  LCD Display Replacement: step 7, image 2 of 3 Kodak Easyshare V1003  LCD Display Replacement: step 7, image 3 of 3
      • Use a plastic opening tool to pry off the back casing.
      Ask FixBot
    3. Kodak Easyshare V1003  LCD Display Replacement: step 8, image 1 of 3 Kodak Easyshare V1003  LCD Display Replacement: step 8, image 2 of 3 Kodak Easyshare V1003  LCD Display Replacement: step 8, image 3 of 3
      • Completely remove the back casing from the device.
      • Using a plastic tool to remove the bottom.
      Ask FixBot
    1. Kodak Easyshare V1003  LCD Display Replacement, LCD Display: step 9, image 1 of 1
      • Remove the LCD display by unplugging the connector.
      Ask FixBot
    2. Kodak Easyshare V1003  LCD Display Replacement: step 10, image 1 of 1
      • Take apart the LCD display from the back case.
      Ask FixBot
2 other people completed this guide.
Vanessa Soares
246 Reputation
2 Guides authored
1 Guide Comment
Hi Vanessa
Where in South Africa (Gauteng) can I buy a lcd display replacement screen for this Kodak easyshare v1003 camera?
Wickus: +27725966377/ vwickus@ymail.com
vwickus - Reply Share
Past 24 Hours: 3
Past 7 Days: 12
Past 30 Days: 40
All Time: 1,567
