Kodak Easyshare C813 Memory Card Replacement
    1. Kodak Easyshare C813 Memory Card Replacement, Memory Card: step 1, image 1 of 1
      • Turn off camera by firmly pressing the power button that is located on the top of the camera near the mode selector dial.
      Ask FixBot
    2. Kodak Easyshare C813 Memory Card Replacement: step 2, image 1 of 3 Kodak Easyshare C813 Memory Card Replacement: step 2, image 2 of 3 Kodak Easyshare C813 Memory Card Replacement: step 2, image 3 of 3
      • Locate battery compartment on bottom of camera and slide open by applying pressure in the direction of the arrow.
      Ask FixBot
    3. Kodak Easyshare C813 Memory Card Replacement: step 3, image 1 of 2 Kodak Easyshare C813 Memory Card Replacement: step 3, image 2 of 2
      • Locate memory card slot and insert memory card by inserting the gold terminals first.
      • Apply pressure into you feel it lock into place.
      • Note: To remove a memory card, apply pressure down until you feel it click. Then it should pop up and you can just pull it up.
      Ask FixBot
    4. Kodak Easyshare C813 Memory Card Replacement: step 4, image 1 of 2 Kodak Easyshare C813 Memory Card Replacement: step 4, image 2 of 2
      • Return the battery door to its formerly closed position.
      Ask FixBot
    5. Kodak Easyshare C813 Memory Card Replacement: step 5, image 1 of 1
      Ask FixBot
Samantha Murray
296 Reputation
3 Guides authored
Cal Poly, Team 24-22, Regan Spring 2010 Member of Cal Poly, Team 24-22, Regan Spring 2010
CPSU-REGAN-S10S24G22
4 Members
120 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 15
Past 30 Days: 66
All Time: 11,128
