Kodak Easyshare C183 Lens Assembly Replacement
  1. Kodak Easyshare C183 Lens Assembly Replacement, Lens: step 1, image 1 of 3 Kodak Easyshare C183 Lens Assembly Replacement, Lens: step 1, image 2 of 3 Kodak Easyshare C183 Lens Assembly Replacement, Lens: step 1, image 3 of 3
    • Remove the batteries, memory card and wrist strap, if so equipped.
    • Remove the three Phillips screws on the bottom.
    • Remove the two Phillips screws on the right hand side.
    Ask FixBot
  2. Kodak Easyshare C183 Lens Assembly Replacement: step 2, image 1 of 3 Kodak Easyshare C183 Lens Assembly Replacement: step 2, image 2 of 3 Kodak Easyshare C183 Lens Assembly Replacement: step 2, image 3 of 3
    • Remove the two screws on the left hand side.
    • Nicely enough, all the screws are the same size. No need to keep them separated.
    • Start splitting the case from the battery holder. You can use an opening tool or just your fingernails.
    Ask FixBot
  3. Kodak Easyshare C183 Lens Assembly Replacement: step 3, image 1 of 3 Kodak Easyshare C183 Lens Assembly Replacement: step 3, image 2 of 3 Kodak Easyshare C183 Lens Assembly Replacement: step 3, image 3 of 3
    • The camera's front half will come off first.
    • Remove the one screw on the top left of the camera. It this holds the back case on to the midframe.
    • Remove the back case.
    Ask FixBot
  4. Kodak Easyshare C183 Lens Assembly Replacement: step 4, image 1 of 3 Kodak Easyshare C183 Lens Assembly Replacement: step 4, image 2 of 3 Kodak Easyshare C183 Lens Assembly Replacement: step 4, image 3 of 3
    • Gently move the LCD out of the holder. DO NOT TRY TO REMOVE THE LCD. Just fold it over.
    • Remove the one screw on the top corner of the holder.
    • Remove the ribbon cable from its connector. It is just pushed in. there are not clips to move. Gently pull it straight down.
    • Remove the solder that connects the LCD holder to the top logic board.
    Ask FixBot
  5. Kodak Easyshare C183 Lens Assembly Replacement: step 5, image 1 of 3 Kodak Easyshare C183 Lens Assembly Replacement: step 5, image 2 of 3 Kodak Easyshare C183 Lens Assembly Replacement: step 5, image 3 of 3
    • The LCD holding board and the switches are removed as one unit.
    • Open the clip on the LCD ribbon cable connector. Use your fingernails to gently pull it toward the top of the camera.
    • Remove the LCD.
    Ask FixBot
  6. Kodak Easyshare C183 Lens Assembly Replacement: step 6, image 1 of 3 Kodak Easyshare C183 Lens Assembly Replacement: step 6, image 2 of 3 Kodak Easyshare C183 Lens Assembly Replacement: step 6, image 3 of 3
    • Open the connectors for the CCD and the lens. Both use a clip that hold the cable is places. Move those gently into the opposite direction of the cables. this will free the cable.
    • Remove the two screws that hold the lens in place.
    • With the screws and the cables removed, use your fingers and push the lens upward and angled out of the midframe.
    Ask FixBot
  7. Kodak Easyshare C183 Lens Assembly Replacement: step 7, image 1 of 1
    • This is what your final result should look like. the lens is now free from the midframe and a new lens can be easily installed.
    Ask FixBot
2 other people completed this guide.
oldturkey03
856,162 Reputation
123 Guides authored
3 Guide Comments
ممنون از اطلاعات تان
hamid kaker - Reply Share
خواهش میکنم. امیدوارم کمک کرده باشد.
oldturkey03 - Reply Share
More I have this camera but I don't know what went wrong, so what went wrong, it is not on camera.
Mohd Ayaz - Reply Share
Past 24 Hours: 4
Past 7 Days: 15
Past 30 Days: 89
All Time: 2,649
