Kodak EasyShare Z740 Lens Cover Replacement
  1. Kodak EasyShare Z740 Lens Cover Replacement, Lens Cover: step 1, image 1 of 2 Kodak EasyShare Z740 Lens Cover Replacement, Lens Cover: step 1, image 2 of 2
    • Remove lens cover from the camera by squeezing the protruding button on each side of the cover and pulling.
    Ask FixBot
  2. Kodak EasyShare Z740 Lens Cover Replacement: step 2, image 1 of 3 Kodak EasyShare Z740 Lens Cover Replacement: step 2, image 2 of 3 Kodak EasyShare Z740 Lens Cover Replacement: step 2, image 3 of 3
    • Pull the lens cover string toward the ground so that the loop underneath the metal slab is on top of the cover string.
    • Push up so that the string starts to come out of the top of the loop.
    • Grab the string from above the loop and pull.
    Ask FixBot
  3. Kodak EasyShare Z740 Lens Cover Replacement: step 3, image 1 of 2 Kodak EasyShare Z740 Lens Cover Replacement: step 3, image 2 of 2
    • Feed the string on top into the metal slab while pulling the loop toward you until the plastic piece stops you from pulling any further.
    Ask FixBot
  4. Kodak EasyShare Z740 Lens Cover Replacement: step 4, image 1 of 3 Kodak EasyShare Z740 Lens Cover Replacement: step 4, image 2 of 3 Kodak EasyShare Z740 Lens Cover Replacement: step 4, image 3 of 3
    • Separate the two pieces of the loop and pull the lens cover up in between them.
    Ask FixBot
  5. Kodak EasyShare Z740 Lens Cover Replacement: step 5, image 1 of 3 Kodak EasyShare Z740 Lens Cover Replacement: step 5, image 2 of 3 Kodak EasyShare Z740 Lens Cover Replacement: step 5, image 3 of 3
    • Pull the lens cover and the sting will come out of the metal slab.
    Ask FixBot
2 other people completed this guide.
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 25
All Time: 1,073
