Kodak EasyShare Z740 LCD Screen Replacement
  1. Kodak EasyShare Z740 LCD Screen Replacement, Battery: step 1, image 1 of 3 Kodak EasyShare Z740 LCD Screen Replacement, Battery: step 1, image 2 of 3 Kodak EasyShare Z740 LCD Screen Replacement, Battery: step 1, image 3 of 3
    • Slide the door on the bottom of the camera in the direction of the open symbol with your finger.
    • Release and the door will pop open.
    Ask FixBot
  2. Kodak EasyShare Z740 LCD Screen Replacement: step 2, image 1 of 2 Kodak EasyShare Z740 LCD Screen Replacement: step 2, image 2 of 2
    • Slide the battery out.
    Ask FixBot
  3. Kodak EasyShare Z740 LCD Screen Replacement, Lens Cover: step 3, image 1 of 2 Kodak EasyShare Z740 LCD Screen Replacement, Lens Cover: step 3, image 2 of 2
    • Remove lens cover from the camera by squeezing the protruding button on each side of the cover and pulling.
    Ask FixBot
  4. Kodak EasyShare Z740 LCD Screen Replacement: step 4, image 1 of 3 Kodak EasyShare Z740 LCD Screen Replacement: step 4, image 2 of 3 Kodak EasyShare Z740 LCD Screen Replacement: step 4, image 3 of 3
    • Pull the lens cover string toward the ground so that the loop underneath the metal slab is on top of the cover string.
    • Push up so that the string starts to come out of the top of the loop.
    • Grab the string from above the loop and pull.
    Ask FixBot
  5. Kodak EasyShare Z740 LCD Screen Replacement: step 5, image 1 of 2 Kodak EasyShare Z740 LCD Screen Replacement: step 5, image 2 of 2
    • Feed the string on top into the metal slab while pulling the loop toward you until the plastic piece stops you from pulling any further.
    Ask FixBot
  6. Kodak EasyShare Z740 LCD Screen Replacement: step 6, image 1 of 3 Kodak EasyShare Z740 LCD Screen Replacement: step 6, image 2 of 3 Kodak EasyShare Z740 LCD Screen Replacement: step 6, image 3 of 3
    • Separate the two pieces of the loop and pull the lens cover up in between them.
    Ask FixBot
  7. Kodak EasyShare Z740 LCD Screen Replacement: step 7, image 1 of 3 Kodak EasyShare Z740 LCD Screen Replacement: step 7, image 2 of 3 Kodak EasyShare Z740 LCD Screen Replacement: step 7, image 3 of 3
    • Pull the lens cover and the sting will come out of the metal slab.
    Ask FixBot
  8. Kodak EasyShare Z740 LCD Screen Replacement, Back Cover: step 8, image 1 of 3 Kodak EasyShare Z740 LCD Screen Replacement, Back Cover: step 8, image 2 of 3 Kodak EasyShare Z740 LCD Screen Replacement, Back Cover: step 8, image 3 of 3
    • Place lens cover back on the lens to prevent scratches or debris but leave string detached.
    • Remove a total of six 3.968mm Phillips #00 screws. Two each from the left side, bottom, and right side.
    Ask FixBot
  9. Kodak EasyShare Z740 LCD Screen Replacement: step 9, image 1 of 3 Kodak EasyShare Z740 LCD Screen Replacement: step 9, image 2 of 3 Kodak EasyShare Z740 LCD Screen Replacement: step 9, image 3 of 3
    • Pull the back cover away from the front cover.
    • You may need to use a plastic opening tool as a wedge if it does not come apart by easily.
    Ask FixBot
  10. Kodak EasyShare Z740 LCD Screen Replacement: step 10, image 1 of 1
    • Separate the back cover from the front cover.
    Ask FixBot
  11. Kodak EasyShare Z740 LCD Screen Replacement, LCD Screen: step 11, image 1 of 3 Kodak EasyShare Z740 LCD Screen Replacement, LCD Screen: step 11, image 2 of 3 Kodak EasyShare Z740 LCD Screen Replacement, LCD Screen: step 11, image 3 of 3
    • Flip the LCD screen down.
    Ask FixBot
  12. Kodak EasyShare Z740 LCD Screen Replacement: step 12, image 1 of 3 Kodak EasyShare Z740 LCD Screen Replacement: step 12, image 2 of 3 Kodak EasyShare Z740 LCD Screen Replacement: step 12, image 3 of 3
    • Locate the two sets of black tabs connecting the flat orange cables to the motherboard.
    • Slide the 2 sets of tabs down with a tool or your finger to release the cables.
    Ask FixBot
  13. Kodak EasyShare Z740 LCD Screen Replacement: step 13, image 1 of 2 Kodak EasyShare Z740 LCD Screen Replacement: step 13, image 2 of 2
    • Gently pull the LCD screen down until the orange cables separate from the motherboard.
    Ask FixBot
2 other people completed this guide.
1 Guide Comment
There isn’t a single image online of the back side of the DS271BK-EZ01B board. Could someone please show the correct way to remove it? I have corrosion on the battery contacts, which may be why I’m having trouble dismounting it. Even just one clear photo of this board’s back side would be incredibly helpful. Thank you!
Nik2010 - Reply Share
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 35
All Time: 1,334
