Kodak EasyShare V570 Case Replacement
  1. Kodak EasyShare V570 Case Replacement, Case: step 1, image 1 of 2 Kodak EasyShare V570 Case Replacement, Case: step 1, image 2 of 2
    • Here is the front, back, and right side of the camera.
    Ask FixBot
  2. Kodak EasyShare V570 Case Replacement: step 2, image 1 of 3 Kodak EasyShare V570 Case Replacement: step 2, image 2 of 3 Kodak EasyShare V570 Case Replacement: step 2, image 3 of 3
    • There are going to be four #000 screws on the left side of the camera.
    • Remove the four corner screws using a Philips #000 Screwdriver.
    • On the right side of the camera, remove the two Phillips #000 screws at the bottom.
    • On the underside of the camera, remove the three Phillips #000 screws.
    Ask FixBot
  3. Kodak EasyShare V570 Case Replacement: step 3, image 1 of 3 Kodak EasyShare V570 Case Replacement: step 3, image 2 of 3 Kodak EasyShare V570 Case Replacement: step 3, image 3 of 3
    • As soon as all the screws from the casing are removed, use the iFixit opening pick to slide around the border.
    • If the cover appears loose, try to take it off (with your fingers) while slightly wiggling it, and it should detach.
    Ask FixBot
  4. Kodak EasyShare V570 Case Replacement: step 4, image 1 of 2 Kodak EasyShare V570 Case Replacement: step 4, image 2 of 2
    • Here is what the camera looks like with both of the covers taken off.
    • The T-W button is upside down.
    • To put the top and back camera covers back on, follow the steps but in reverse.
    Ask FixBot
Finish Line
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 30
All Time: 427
