Kodak EasyShare M381 Screen Replacement
    1. Kodak EasyShare M381 Screen Replacement, Battery: step 1, image 1 of 2 Kodak EasyShare M381 Screen Replacement, Battery: step 1, image 2 of 2
      • First, press in and slide forward the battery latch as indicated by the arrow.
      Ask FixBot
    2. Kodak EasyShare M381 Screen Replacement: step 2, image 1 of 1
      • Press down on battery until you hear a click and release it. Battery should easily slide out.
      Ask FixBot
    1. Kodak EasyShare M381 Screen Replacement, Back Panel Frame: step 3, image 1 of 3 Kodak EasyShare M381 Screen Replacement, Back Panel Frame: step 3, image 2 of 3 Kodak EasyShare M381 Screen Replacement, Back Panel Frame: step 3, image 3 of 3
      • Remove the 3.9 mm frame screws using a Phillips #00 screwdriver.
      • Using a magnetized surface to keep from losing screws may be very helpful.
      Ask FixBot
    2. Kodak EasyShare M381 Screen Replacement: step 4, image 1 of 2 Kodak EasyShare M381 Screen Replacement: step 4, image 2 of 2
      • Using both hands, carefully pull the frame apart from the camera.
      Ask FixBot
    1. Kodak EasyShare M381 Screen Replacement, Screen: step 5, image 1 of 1
      • Remove the two 3.85 mm screws on the bottom right of the camera, as indicated.
      Ask FixBot
    2. Kodak EasyShare M381 Screen Replacement: step 6, image 1 of 1
      • Remove dial button located on top of camera, by gently pulling up.
      Ask FixBot
    3. Kodak EasyShare M381 Screen Replacement: step 7, image 1 of 2 Kodak EasyShare M381 Screen Replacement: step 7, image 2 of 2
      • Starting at one side, carefully work the chrome frame off of the camera itself.
      • Be careful not to disturb the shutter or flash buttons on top of the camera.
      Ask FixBot
    4. Kodak EasyShare M381 Screen Replacement: step 8, image 1 of 1
      • On the right side of the camera, locate and remove the two 3.25 mm screws as highlighted.
      Ask FixBot
    5. Kodak EasyShare M381 Screen Replacement: step 9, image 1 of 3 Kodak EasyShare M381 Screen Replacement: step 9, image 2 of 3 Kodak EasyShare M381 Screen Replacement: step 9, image 3 of 3
      • Carefully lift the motherboard panel up, pulling towards the left. Make sure you do not rip the blue ribbon.
      • Using a plastic opening tool, gently lift up on the ribbon fastener until it is in an upright position.
      • Slide panel away from camera.
      Ask FixBot
    6. Kodak EasyShare M381 Screen Replacement: step 10, image 1 of 2 Kodak EasyShare M381 Screen Replacement: step 10, image 2 of 2
      • Using a plastic opening tool, gently lift ribbon clamp as indicated to remove the screen ribbon from the motherboard.
      • Screen should now be detached. Gently lift it away from the base of the camera.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 49
All Time: 956
