Kodak EasyShare M381 Button Replacement
    1. Kodak EasyShare M381 Button Replacement, Battery: step 1, image 1 of 2 Kodak EasyShare M381 Button Replacement, Battery: step 1, image 2 of 2
      • First, press in and slide forward the battery latch as indicated by the arrow.
      Ask FixBot
    2. Kodak EasyShare M381 Button Replacement: step 2, image 1 of 1
      • Press down on battery until you hear a click and release it. Battery should easily slide out.
      Ask FixBot
    1. Kodak EasyShare M381 Button Replacement, Back Panel Frame: step 3, image 1 of 3 Kodak EasyShare M381 Button Replacement, Back Panel Frame: step 3, image 2 of 3 Kodak EasyShare M381 Button Replacement, Back Panel Frame: step 3, image 3 of 3
      • Remove the 3.9 mm frame screws using a Phillips #00 screwdriver.
      • Using a magnetized surface to keep from losing screws may be very helpful.
      Ask FixBot
    2. Kodak EasyShare M381 Button Replacement: step 4, image 1 of 2 Kodak EasyShare M381 Button Replacement: step 4, image 2 of 2
      • Using both hands, carefully pull the frame apart from the camera.
      Ask FixBot
    1. Kodak EasyShare M381 Button Replacement, Button: step 5, image 1 of 1
      • Carefully pick up frame and push upward on buttons.
      Ask FixBot
    2. Kodak EasyShare M381 Button Replacement: step 6, image 1 of 1
      • Clean and replace as needed.
      • A microfiber cloth, or any other type of electronic cloth may be used to clean them if desire.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 27
All Time: 627
