Better Introduction
Improve this guide by completing or revising its introduction.
Introduction
Go to step 1 ↓This will teach you how to remove the capacitor in your Kodak EasyShare LS743.
Tools
Using a Phillips #00 screwdriver, remove two 5.39 mm screws next to the battery slot.
Remove the metal piece holding down the lanyard, then remove the lanyard.
Using a Phillips #00 screwdriver, remove seven screws located on the outside case of the camera.
One 6.25 mm screw is located on the top right corner, right to the "OK" button.
Four 4.45 mm screws are on the bottom of the camera.
Two 2.95 mm screws are on the left side of the camera, above the USB port.
Tool used on this step:Tweezers$4.99
Connect the two capacitor wires briefly with a pair of metal tweezers to discharge the capacitor. You may see a small spark.
Remove eight screws using a Phillips #00 screwdriver.
Two (4.31 mm) screws are in the front of the camera.
Two (3.30 mm) screws are located in the bottom of the camera.
Four (3 x 3.33 mm and 1 x 4.34 mm) screws are in the back of the camera.
