Kodak EasyShare LS743 Camera Case Disassembly
    1. Kodak EasyShare LS743 Camera Case Disassembly, Kodak EasyShare LS743 Camera Case Disassembly: step 1, image 1 of 3 Kodak EasyShare LS743 Camera Case Disassembly, Kodak EasyShare LS743 Camera Case Disassembly: step 1, image 2 of 3 Kodak EasyShare LS743 Camera Case Disassembly, Kodak EasyShare LS743 Camera Case Disassembly: step 1, image 3 of 3
      • Using a Phillips #00 screwdriver, remove two 5.39 mm screws next to the battery slot.
      • Remove the metal piece holding down the lanyard, then remove the lanyard.
      Ask FixBot
    2. Kodak EasyShare LS743 Camera Case Disassembly: step 2, image 1 of 3 Kodak EasyShare LS743 Camera Case Disassembly: step 2, image 2 of 3 Kodak EasyShare LS743 Camera Case Disassembly: step 2, image 3 of 3
      • Using a Phillips #00 screwdriver, remove seven screws located on the outside case of the camera.
      • One 6.25 mm screw is located on the top right corner, right to the "OK" button.
      • Four 4.45 mm screws are on the bottom of the camera.
      • Two 2.95 mm screws are on the left side of the camera, above the USB port.
      Ask FixBot
    3. Kodak EasyShare LS743 Camera Case Disassembly: step 3, image 1 of 2 Kodak EasyShare LS743 Camera Case Disassembly: step 3, image 2 of 2
      • Carefully remove the rear camera casing.
      • Carefully remove the front camera casing.
      Ask FixBot
Michael
63 Reputation
2 Guides authored
Cal Poly, Team 2-8, Johann Summer 2010 Member of Cal Poly, Team 2-8, Johann Summer 2010
CPSU-JOHANN-R10S2G8
5 Members
93 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 5
Past 30 Days: 31
All Time: 2,482
