Kodak EasyShare CD82 Lens Assembly Replacement
Views: 2.5K
View statistics:
Past 24 Hours:
2
Past 7 Days:
17
Past 30 Days:
113
All Time:
2,530
Comments: 1
1 guide comment.
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 5
5 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 1 hour
Difficulty: Moderate
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Needs More Images
A few more images would make this guide's procedures crystal clear.
Slice and Dice
The steps in this guide should be split up and made into a series of prerequisite guides.
Community-Contributed Guide
Introduction
Go to step 1 ↓
Use this guide to remove and replace a dysfunctional lens on the Kodak EasyShare CD82 digital camera.
Parts
Tools
    1. Kodak EasyShare CD82 Lens Assembly Replacement, Lens Assembly: step 1, image 1 of 3 Kodak EasyShare CD82 Lens Assembly Replacement, Lens Assembly: step 1, image 2 of 3 Kodak EasyShare CD82 Lens Assembly Replacement, Lens Assembly: step 1, image 3 of 3
      • Remove the batteries and the memory card from the device.
      • Remove the two screws located at the bottom of the camera.
      Ask FixBot
    2. Kodak EasyShare CD82 Lens Assembly Replacement: step 2, image 1 of 3 Kodak EasyShare CD82 Lens Assembly Replacement: step 2, image 2 of 3 Kodak EasyShare CD82 Lens Assembly Replacement: step 2, image 3 of 3
      • Remove the two screws on the side of the device, to left of the camera lens.
      • Remove the two screws on side of the device, to the right of the camera lens.
      • Pry the casing apart at the seems, starting at the battery compartment.
      Ask FixBot
    3. Kodak EasyShare CD82 Lens Assembly Replacement: step 3, image 1 of 3 Kodak EasyShare CD82 Lens Assembly Replacement: step 3, image 2 of 3 Kodak EasyShare CD82 Lens Assembly Replacement: step 3, image 3 of 3
      • Remove the front casing from the mid-frame, first.
      • Continue to remove the back casing from the mid-frame.
      • Do not remove the LCD screen from the device once it becomes visible.
      Ask FixBot
    4. Kodak EasyShare CD82 Lens Assembly Replacement: step 4, image 1 of 3 Kodak EasyShare CD82 Lens Assembly Replacement: step 4, image 2 of 3 Kodak EasyShare CD82 Lens Assembly Replacement: step 4, image 3 of 3
      • Flip the LCD screen out of the holder from the top to reveal ribbon cable.
      • This camera had some obvious water damage..
      • Remove the three screws from the LCD holder
      • Dislodge the LCD screen holder from the circuit board connector.
      Ask FixBot
    5. Kodak EasyShare CD82 Lens Assembly Replacement: step 5, image 1 of 3 Kodak EasyShare CD82 Lens Assembly Replacement: step 5, image 2 of 3 Kodak EasyShare CD82 Lens Assembly Replacement: step 5, image 3 of 3
      Tool used on this step:
      Buy
      • Disconnect the logic board from the frame on the right side of the device.
      • Remove the small ribbon cable, connecting the button board to the logic board, with small pair of tweezers or hemostat.
      • Remove the screw on the top right side of the device connecting the LCD screen holder to the midframe.
      • Move the black clip into the upward position to disconnect the cable.
      • You will now be able to remove the LCD screen and its holder from the device.
      Ask FixBot
    6. Kodak EasyShare CD82 Lens Assembly Replacement: step 6, image 1 of 3 Kodak EasyShare CD82 Lens Assembly Replacement: step 6, image 2 of 3 Kodak EasyShare CD82 Lens Assembly Replacement: step 6, image 3 of 3
      • Flip the black clips of the connectors into the opposite direction. Remove the lens and CCD cable.
      • Remove the two screws securing the lens to the midframe.
      • These are missing screws for the CCD sensor, lost in a previous dismantling.
      • Remove the single screw securing the lens to the mid-frame. The lens will now be loose.
      • Push the lens out of the frame in an angular direction, and remove.
      Ask FixBot
    7. Kodak EasyShare CD82 Lens Assembly Replacement: step 7, image 1 of 1
      • Insert the new lens the same way it was removed.
      • Clean and reassemble the camera.
      Ask FixBot
oldturkey03
863,283 Reputation
123 Guides authored
1 Guide Comment
When it says "Dislodge the LCD screen holder from the circuit board connector" does it mean that I can break that solder without desoldering and it's okay?
Sith Siri - Reply Share
Past 24 Hours: 2
Past 7 Days: 17
Past 30 Days: 113
All Time: 2,530
