Kodak EasyShare CD82 LCD Display Screen Replacement
    1. Kodak EasyShare CD82 LCD Display Screen Replacement, LCD Screen: step 1, image 1 of 3 Kodak EasyShare CD82 LCD Display Screen Replacement, LCD Screen: step 1, image 2 of 3 Kodak EasyShare CD82 LCD Display Screen Replacement, LCD Screen: step 1, image 3 of 3
      • Remove the batteries and the memory card from the device.
      • Remove the 2 screws located at the bottom of the device.
      Ask FixBot
    2. Kodak EasyShare CD82 LCD Display Screen Replacement: step 2, image 1 of 3 Kodak EasyShare CD82 LCD Display Screen Replacement: step 2, image 2 of 3 Kodak EasyShare CD82 LCD Display Screen Replacement: step 2, image 3 of 3
      • Remove the 2 screws on the side, to the left of the camera lens.
      • Remove the 2 screws on the side, to the right of the camera lens.
      • Pry the casing from the device starting at the battery compartment and following the seem around the camera.
      Ask FixBot
    3. Kodak EasyShare CD82 LCD Display Screen Replacement: step 3, image 1 of 3 Kodak EasyShare CD82 LCD Display Screen Replacement: step 3, image 2 of 3 Kodak EasyShare CD82 LCD Display Screen Replacement: step 3, image 3 of 3
      • Remove the front panel from the device first, then remove the back panel.
      • Do not remove the LCD screen from the device once it becomes visible.
      Ask FixBot
    4. Kodak EasyShare CD82 LCD Display Screen Replacement: step 4, image 1 of 3 Kodak EasyShare CD82 LCD Display Screen Replacement: step 4, image 2 of 3 Kodak EasyShare CD82 LCD Display Screen Replacement: step 4, image 3 of 3
      • Flip the LCD screen away from the top of the device to reveal the ribbon cable.
      • This is water damage the has afflicted the camera.
      • Remove the 3 screws from the LCD screen holder.
      • Pry the screen holder from the circuit board connector.
      Ask FixBot
    5. Kodak EasyShare CD82 LCD Display Screen Replacement: step 5, image 1 of 2 Kodak EasyShare CD82 LCD Display Screen Replacement: step 5, image 2 of 2
      Tool used on this step:
      Buy
      • Disconnect the logic board from the right side of the frame.
      • Remove the small ribbon cable that is connecting the button panel to the logic board, using a small pair of tweezers or hemostat.
      • Remove the screw on the top right side of the device.
      Ask FixBot
    6. Kodak EasyShare CD82 LCD Display Screen Replacement: step 6, image 1 of 2 Kodak EasyShare CD82 LCD Display Screen Replacement: step 6, image 2 of 2
      • Open the connector and move the black clip into the upward position, freeing the cable. Remove the LCD screen and the holder.
      • While the camera is disassembled, use isopropyl alcohol to remove rust and clean the device.
      • Follow these steps in reverse order to reassemble. The device should be fully functional upon completion.
      Ask FixBot
2 other people completed this guide.
oldturkey03
859,669 Reputation
123 Guides authored
1 Guide Comment
Is there any repair for Kodak CD80 easy share camera…..as my camera is not working
Januchowdary - Reply Share
Past 24 Hours: 2
Past 7 Days: 11
Past 30 Days: 48
All Time: 2,154
