Kodak EasyShare C913 Capacitor Replacement
    1. Kodak EasyShare C913 Capacitor Replacement, Batteries: step 1, image 1 of 3 Kodak EasyShare C913 Capacitor Replacement, Batteries: step 1, image 2 of 3 Kodak EasyShare C913 Capacitor Replacement, Batteries: step 1, image 3 of 3
      • Position the camera with the bottom facing up.
      • Slide the battery cover in the direction of the arrow with your finger gently.
      • Remove the batteries
      Ask FixBot
    1. Kodak EasyShare C913 Capacitor Replacement, Back Case: step 2, image 1 of 3 Kodak EasyShare C913 Capacitor Replacement, Back Case: step 2, image 2 of 3 Kodak EasyShare C913 Capacitor Replacement, Back Case: step 2, image 3 of 3
      • Remove the seven 4.5mm screws with a Phillips #00 screwdriver.
      • 2 screws on the left, 2 screws on the right, 3 screws on the bottom
      Ask FixBot
    2. Kodak EasyShare C913 Capacitor Replacement: step 3, image 1 of 3 Kodak EasyShare C913 Capacitor Replacement: step 3, image 2 of 3 Kodak EasyShare C913 Capacitor Replacement: step 3, image 3 of 3
      • Firmly grasp the back of the camera and pull the casing away.
      Ask FixBot
    1. Kodak EasyShare C913 Capacitor Replacement, Front Case: step 4, image 1 of 3 Kodak EasyShare C913 Capacitor Replacement, Front Case: step 4, image 2 of 3 Kodak EasyShare C913 Capacitor Replacement, Front Case: step 4, image 3 of 3
      • Keep the battery door open
      • Firmly grasp the front casing and pull it away from the camera.
      Ask FixBot
    1. Kodak EasyShare C913 Capacitor Replacement, Capacitor: step 5, image 1 of 2 Kodak EasyShare C913 Capacitor Replacement, Capacitor: step 5, image 2 of 2
      • Orient the camera with the lens facing you.
      • Use a Phillips #00 screwdriver to remove the one 2.2mm screw on the plastic bridge.
      • Lift the plastic bridge off and place it to the side.
      Ask FixBot
    2. Kodak EasyShare C913 Capacitor Replacement: step 6, image 1 of 1
      • Do not touch the capacitor contact points for any reason. This will result in a severe shock.
      Ask FixBot
    3. Kodak EasyShare C913 Capacitor Replacement: step 7, image 1 of 3 Kodak EasyShare C913 Capacitor Replacement: step 7, image 2 of 3 Kodak EasyShare C913 Capacitor Replacement: step 7, image 3 of 3
      • Grasp the capacitor, carefully remove it from its holder, and place it off to the side.
      Ask FixBot
    4. Kodak EasyShare C913 Capacitor Replacement: step 8, image 1 of 1
      • De-solder the connections at the base of the capacitor
      Ask FixBot
Alan Galarza
84 Reputation
3 Guides authored
Cal Poly, Team 7-51, Amido Fall 2010 Member of Cal Poly, Team 7-51, Amido Fall 2010
CPSU-AMIDO-F10S7G51
4 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 19
Past 30 Days: 62
All Time: 4,762
