Kodak EasyShare C913 Buttons Replacement
    1. Kodak EasyShare C913 Buttons Replacement, Batteries: step 1, image 1 of 3 Kodak EasyShare C913 Buttons Replacement, Batteries: step 1, image 2 of 3 Kodak EasyShare C913 Buttons Replacement, Batteries: step 1, image 3 of 3
      • Position the camera with the bottom facing up.
      • Slide the battery cover in the direction of the arrow with your finger gently.
      • Remove the batteries
      Ask FixBot
    1. Kodak EasyShare C913 Buttons Replacement, Back Case: step 2, image 1 of 3 Kodak EasyShare C913 Buttons Replacement, Back Case: step 2, image 2 of 3 Kodak EasyShare C913 Buttons Replacement, Back Case: step 2, image 3 of 3
      • Remove the seven 4.5mm screws with a Phillips #00 screwdriver.
      • 2 screws on the left, 2 screws on the right, 3 screws on the bottom
      Ask FixBot
    2. Kodak EasyShare C913 Buttons Replacement: step 3, image 1 of 3 Kodak EasyShare C913 Buttons Replacement: step 3, image 2 of 3 Kodak EasyShare C913 Buttons Replacement: step 3, image 3 of 3
      • Firmly grasp the back of the camera and pull the casing away.
      Ask FixBot
    1. Kodak EasyShare C913 Buttons Replacement, Buttons: step 4, image 1 of 3 Kodak EasyShare C913 Buttons Replacement, Buttons: step 4, image 2 of 3 Kodak EasyShare C913 Buttons Replacement, Buttons: step 4, image 3 of 3
      • Use #00 screwdriver to pry off buttons.
      Ask FixBot
Alan Galarza
84 Reputation
3 Guides authored
Cal Poly, Team 7-51, Amido Fall 2010 Member of Cal Poly, Team 7-51, Amido Fall 2010
CPSU-AMIDO-F10S7G51
4 Members
84 Guides authored
1 Guide Comment
Thank you this was very helpful!
carolnelson - Reply Share
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 28
All Time: 1,791
