Kodak EasyShare C713 Outer Case Replacement
  1. Kodak EasyShare C713 Outer Case Replacement, Batteries: step 1, image 1 of 1
    • Use your finger tip to slide battery cover door away from the center of the camera.
    • The battery door should spring open.
    • If this does not happen, gently open the door lifting from the outer bottom side of the camera.
    Ask FixBot
  2. Kodak EasyShare C713 Outer Case Replacement: step 2, image 1 of 1
    • Remove the old batteries.
    Ask FixBot
  3. Kodak EasyShare C713 Outer Case Replacement, Outer Case: step 3, image 1 of 3 Kodak EasyShare C713 Outer Case Replacement, Outer Case: step 3, image 2 of 3 Kodak EasyShare C713 Outer Case Replacement, Outer Case: step 3, image 3 of 3
    • Remove the seven screws from the outer case with a Phillips #00.
    • All screws are 4.45mm.
    • There are 2 screws on the port side.
    • There are 2 screws on starboard side.
    • There are 3 screws on the bottom.
    Ask FixBot
  4. Kodak EasyShare C713 Outer Case Replacement: step 4, image 1 of 3 Kodak EasyShare C713 Outer Case Replacement: step 4, image 2 of 3 Kodak EasyShare C713 Outer Case Replacement: step 4, image 3 of 3
    • Make sure the battery cap is "up".
    • Pull the outer case off with your hands.
    Ask FixBot
3 other people completed this guide.
Taggart Ashby
360 Reputation
4 Guides authored
Cal Poly, Team 26-19, Regan Spring 2010 Member of Cal Poly, Team 26-19, Regan Spring 2010
CPSU-REGAN-S10S26G19
4 Members
14 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 8
Past 30 Days: 37
All Time: 3,082
