Kodak EasyShare C195 Memory Card Replacement
    1. Kodak EasyShare C195 Memory Card Replacement, Memory Card: step 1, image 1 of 3 Kodak EasyShare C195 Memory Card Replacement, Memory Card: step 1, image 2 of 3 Kodak EasyShare C195 Memory Card Replacement, Memory Card: step 1, image 3 of 3
      • First, access the slide door on the bottom left corner of the camera. To open, push down and to the left.
      Ask FixBot
    2. Kodak EasyShare C195 Memory Card Replacement: step 2, image 1 of 3 Kodak EasyShare C195 Memory Card Replacement: step 2, image 2 of 3 Kodak EasyShare C195 Memory Card Replacement: step 2, image 3 of 3
      • The memory card slot is located just below the batteries.
      • To insert the memory card, make sure the writing is facing the batteries, and the cut off corner is at the top right. Put the card into the slot and push until you hear a click.
      • You do not need to remove the batteries to insert the memory card.
      Ask FixBot
    3. Kodak EasyShare C195 Memory Card Replacement: step 3, image 1 of 1
      • This is what the memory card should look like when finished.
      Ask FixBot
To remove, push the memory card until you feel a click. The card should pop out.
Alyssa
101 Reputation
4 Guides authored
Cal Poly, Team 6-22, Amido Spring 2012 Member of Cal Poly, Team 6-22, Amido Spring 2012
CPSU-AMIDO-S12S6G22
4 Members
48 Guides authored
2 Guide Comments
Hi. I purchased a new memory card. When inserted into the camera, I can’t take a picture because the camera states internal memory full. What do I do??
katherine skorich-nelson - Reply Share
Bought a new memory card. Cannot take pictures because the screen states "internal memory full”. What do I do?
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 32
All Time: 3,212
