Kocaso M750B Display Replacement
    1. Kocaso M750B Display Replacement, Backplate: step 1, image 1 of 3 Kocaso M750B Display Replacement, Backplate: step 1, image 2 of 3 Kocaso M750B Display Replacement, Backplate: step 1, image 3 of 3
      • Pry the edges of the tablet apart using an iFixit opening tool.
      Ask FixBot
    1. Kocaso M750B Display Replacement, Display: step 2, image 1 of 2 Kocaso M750B Display Replacement, Display: step 2, image 2 of 2
      • Remove three 1.2 mm screws from the motherboard using a Phillips #000 screwdriver.
      Ask FixBot
    2. Kocaso M750B Display Replacement: step 3, image 1 of 1
      • Disconnect the ribbon cables.
      • This guide will help you identify what type of ribbon cables the tablet uses and helps you on how exactly to remove different types of ribbon cables. The exact ribbon cables you are looking for are called ZIF connectors.
      Ask FixBot
    3. Kocaso M750B Display Replacement: step 4, image 1 of 1
      • Desolder the connections to the motherboard and the display.
      • When using the soldering iron, make sure to review the safety guidelines provided in the introduction. Work carefully and precisely to avoid any electrical discharge, puncture of the battery, or heating of the motherboard.
      Ask FixBot
    4. Kocaso M750B Display Replacement: step 5, image 1 of 2 Kocaso M750B Display Replacement: step 5, image 2 of 2
      • Remove the display by loosening the tabs surrounding it.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 12
Past 30 Days: 54
All Time: 344
