Kocaso M750B Camera Replacement
    1. Kocaso M750B Camera Replacement, Backplate: step 1, image 1 of 3 Kocaso M750B Camera Replacement, Backplate: step 1, image 2 of 3 Kocaso M750B Camera Replacement, Backplate: step 1, image 3 of 3
      • Pry the edges of the tablet apart using an iFixit opening tool.
      Ask FixBot
    1. Kocaso M750B Camera Replacement, Camera: step 2, image 1 of 2 Kocaso M750B Camera Replacement, Camera: step 2, image 2 of 2
      • Pry the battery up using the flat end of a spudger.
      • Remove the adhesive under the battery and carefully lift it up.
      Ask FixBot
    2. Kocaso M750B Camera Replacement: step 3, image 1 of 2 Kocaso M750B Camera Replacement: step 3, image 2 of 2
      • Detach the ribbon cable connecting the camera to the motherboard.
      • For more information about ribbon cables, visit this guide.
      • Gently pull on the black strip away from the motherboard. Once you hear a slight click, the ribbon cable should now come loose.
      • You can now remove the camera.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 24
Past 30 Days: 72
All Time: 395
