Kobo Vox Battery Replacement
    1. Kobo Vox Battery Replacement, Battery: step 1, image 1 of 1
      • Your Kobo Vox
      Ask FixBot
    2. Kobo Vox Battery Replacement: step 2, image 1 of 1
      • The back of your Kobo Vox
      Ask FixBot
    3. Kobo Vox Battery Replacement: step 3, image 1 of 1
      • Slide your plastic opening tool along the edge of the back cover to pop it open.
      Ask FixBot
    4. Kobo Vox Battery Replacement: step 4, image 1 of 1
      • The back cover should start to pop open like this.
      Ask FixBot
    5. Kobo Vox Battery Replacement: step 5, image 1 of 1
      • During Reassembly this is where the plastic snaps are located on the back cover. They will have to be lined up in order for it to snap back into place correctly.
      Ask FixBot
    6. Kobo Vox Battery Replacement: step 6, image 1 of 1
      • This is what the inside of your Kobo Vox should look like
      Ask FixBot
    7. Kobo Vox Battery Replacement: step 7, image 1 of 1
      • If the battery connector looks like this, it may not be making perfect contact, and your tablet may not turn on properly.
      Ask FixBot
    8. Kobo Vox Battery Replacement: step 8, image 1 of 1
      • Push the connector as far into its socket as you can.
      • You can put a piece of tape over this connector if you are afraid it will disconnect again.
      Ask FixBot
To reassemble your device, follow these instructions in reverse order. All you have to do is snap in the back cover.
6 other people completed this guide.
Nick B
292 Reputation
1 Guide authored
1 Guide Comment
hoe and where do I get replacement battery
terryyvette - Reply Share
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 25
All Time: 3,860
