Up to 20% off select tools
Kobo Mini Disassembly
Views: 8.3K
View statistics:
Past 24 Hours:
3
Past 7 Days:
26
Past 30 Days:
173
All Time:
8,269
Comments: 9
9 guide comments.
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 - 45 minutes
Difficulty: Moderate
Community-Contributed Guide
Tools
    1. Kobo Mini Disassembly, Kobo Mini Disassembly: step 1, image 1 of 2 Kobo Mini Disassembly, Kobo Mini Disassembly: step 1, image 2 of 2
      • Pull on the corner to remove the cover.
      Ask FixBot
    2. Kobo Mini Disassembly: step 2, image 1 of 1
      • Remove the six screws.
      • Remove the back of the device.
      Ask FixBot
    3. Kobo Mini Disassembly: step 3, image 1 of 1
      • Remove the four screws from the mother board.
      • Remove the screen connector and the battery connector.
      • Remove the micro SD card.
      • Remove the motherboard from the chassis.
      Ask FixBot
    4. Kobo Mini Disassembly: step 4, image 1 of 2 Kobo Mini Disassembly: step 4, image 2 of 2
      • Remove the four screws from the screen frame.
      • Remove the screen
      Ask FixBot
    5. Kobo Mini Disassembly: step 5, image 1 of 1
      • And we finally finished.
      Ask FixBot
Finish Line
3 other people completed this guide.
Author
with
Gabriel Bédard
360 Reputation
1 Guide authored
9 Guide Comments
Just a quick note, I noticed that the SD card in the teardown is a 4gb one. The Kobo Mini has only 2gb of storage. There's just under 2gb of unpartitioned space. You can use a partition manager to extend out the last partition to fill the card, and get close to 4gb of space.
There's a guide over on Mobile Read: https://www.mobileread.com/forums/showth...
Stephanie Raccoon - Reply Share
Yes I think
Gabriel Bédard - Reply Share
Thanks for the teardown! See https://www.mobileread.com/forums/showth... and https://wiki.mobileread.com/wiki/Kobo_Mi... for more disassembly advice and information about the components used.
I would be concerned about the reliability of the 4GB micro SD cards when extended to use the full unpartitioned space. While I could imagine a situation where 4GB cards were used due to unavailability of 2GB cards, there doesn’t seem to be a good reason to only format them to 2GB unless they were only guaranteed to reliably hold 2GB of data. In other words, I wonder if they were originally 4GB cards that failed some QA test and were only rated for use as 2GB capacity cards.
David Boddie - Reply Share
How do you remove the battery connector? Simply pull? Remove the black little things on the sides in some way?
jasonhayden - Reply Share
Yes you just need to pull it from the motherboard
Past 24 Hours: 3
Past 7 Days: 26
Past 30 Days: 173
All Time: 8,269
