Kobo Libra Colour (N428) Battery Replacement
  1. Kobo Libra Colour (N428) Battery Replacement, Before you begin: step 1, image 1 of 3 Kobo Libra Colour (N428) Battery Replacement, Before you begin: step 1, image 2 of 3 Kobo Libra Colour (N428) Battery Replacement, Before you begin: step 1, image 3 of 3
    • Drain your eReader's battery as much as possible before starting your repair. Ideally, it should be fully discharged.
    • Optionally, to drain the battery faster, navigate to MoreSettingsEnergy saving and privacy and set Automatically go to sleep after and Automatically power off after to Never.
    • When working on or near the battery, don't use sharp metal tools to avoid puncturing and shorting the battery.
    • Unplug all cables and fully shut down your eReader.
    • Your screen should be black and say Powered off.
    Ask FixBot
  2. Kobo Libra Colour (N428) Battery Replacement, Insert an opening pick: step 2, image 1 of 3 Kobo Libra Colour (N428) Battery Replacement, Insert an opening pick: step 2, image 2 of 3 Kobo Libra Colour (N428) Battery Replacement, Insert an opening pick: step 2, image 3 of 3
    • Flip your eReader over so the screen is facing down.
    • Angle an opening pick straight down, and insert its tip under the top right corner of the back cover, near the power button.
    • Push downward and pry up with the pick until you feel it slide between one of the clips and the frame.
    • You may have to test a few spots along the corner until the pick slides between one of the clips.
    Ask FixBot
  3. Kobo Libra Colour (N428) Battery Replacement, Release the right clips: step 3, image 1 of 3 Kobo Libra Colour (N428) Battery Replacement, Release the right clips: step 3, image 2 of 3 Kobo Libra Colour (N428) Battery Replacement, Release the right clips: step 3, image 3 of 3
    • Slide the pick toward the bottom right corner to release the clips along the right edge.
    Ask FixBot
  4. Kobo Libra Colour (N428) Battery Replacement: step 4, image 1 of 2 Kobo Libra Colour (N428) Battery Replacement: step 4, image 2 of 2
    • Angle the pick flat under the back cover and rotate it around the bottom right corner to release its clips.
    • If you're having trouble, try twisting the pick to lift the corner clips out of their slots.
    Ask FixBot
  5. Kobo Libra Colour (N428) Battery Replacement, Release the bottom clips: step 5, image 1 of 3 Kobo Libra Colour (N428) Battery Replacement, Release the bottom clips: step 5, image 2 of 3 Kobo Libra Colour (N428) Battery Replacement, Release the bottom clips: step 5, image 3 of 3
    • Slide the pick toward the bottom left corner to release the clips along the bottom edge.
    Ask FixBot
  6. Kobo Libra Colour (N428) Battery Replacement, Remove the back cover: step 6, image 1 of 3 Kobo Libra Colour (N428) Battery Replacement, Remove the back cover: step 6, image 2 of 3 Kobo Libra Colour (N428) Battery Replacement, Remove the back cover: step 6, image 3 of 3
    • At this point, you should be able to grip the back cover and release its remaining clips. If not, slide a pick under the perimeter of the back cover until you can grip an edge.
    • Grip the right edge of the back cover and lift it away from the eReader to release the remaining clips.
    • Remove the back cover.
    • During reassembly, align the back cover over the eReader and press along the perimeter until all its clips snap back into place.
    Ask FixBot
  7. Kobo Libra Colour (N428) Battery Replacement, Coating information: step 7, image 1 of 3 Kobo Libra Colour (N428) Battery Replacement, Coating information: step 7, image 2 of 3 Kobo Libra Colour (N428) Battery Replacement, Coating information: step 7, image 3 of 3
    • The entire surface of the eReader's internals is covered in a thin, plastic-like waterproof coating. Keep the following in mind as you continue disassembly:
    • While this won't hurt your device, removing the coating compromises the device to potential water damage.
    • The coating is brittle and can flake into many small pieces. Heating the coating helps, but working with it is still a time-consuming process.
    • Depending on your repair, you might have to remove the coating from ZIF connectors and their cables.
    Ask FixBot
  8. Kobo Libra Colour (N428) Battery Replacement, Disconnect the battery: step 8, image 1 of 2 Kobo Libra Colour (N428) Battery Replacement, Disconnect the battery: step 8, image 2 of 2
    • Use a spudger to pry up and disconnect the battery press connector.
    • Don't pry against the motherboard, as you risk breaking small, surface-mounted components.
    • Your E-ink screen will continue to say Powered off even after disconnection—this is normal!
    Ask FixBot
  9. Kobo Libra Colour (N428) Battery Replacement, Peel up the battery cable: step 9, image 1 of 2 Kobo Libra Colour (N428) Battery Replacement, Peel up the battery cable: step 9, image 2 of 2
    Tool used on this step:
    Buy
    • Use tweezers, or your fingers, to peel the battery cable away the motherboard and separate the coating.
    Ask FixBot
  10. Kobo Libra Colour (N428) Battery Replacement, Battery information: step 10, image 1 of 1
    • When working on or near the battery, don't use sharp metal tools to avoid puncturing and shorting the battery! A punctured battery can leak dangerous chemicals and catch fire.
    • If your battery comes with stretch release adhesive, follow the next two steps to remove them.
    • Otherwise, skip ahead two steps to remove the normal adhesive.
    Ask FixBot
  11. Kobo Libra Colour (N428) Battery Replacement, Remove the stretch release adhesive: step 11, image 1 of 3 Kobo Libra Colour (N428) Battery Replacement, Remove the stretch release adhesive: step 11, image 2 of 3 Kobo Libra Colour (N428) Battery Replacement, Remove the stretch release adhesive: step 11, image 3 of 3
    • Grip a black pull tab and pull the strip out slowly and steadily at a low angle. Give it plenty of time to stretch and un-stick from under the battery.
    • You can also wrap an adhesive strip around a spudger and "roll" it for a more consistent pull.
    • If the adhesive strip breaks off, try to retrieve it using your fingers and continue pulling—but don’t pry under the battery.
    • If you can't retrieve a strip, don't worry! Remove as much adhesive as possible and skip down two steps for an alternate method.
    Ask FixBot
  12. Kobo Libra Colour (N428) Battery Replacement, Remove the battery: step 12, image 1 of 3 Kobo Libra Colour (N428) Battery Replacement, Remove the battery: step 12, image 2 of 3 Kobo Libra Colour (N428) Battery Replacement, Remove the battery: step 12, image 3 of 3
    • The battery is still lightly held to the frame by the coating.
    • Insert the long side of an opening pick under different edges of the battery to separate the coating.
    • Don't bend or crease the battery! Make sure all of the coating is separated before removing the battery.
    • Remove the battery.
    Ask FixBot
  13. Kobo Libra Colour (N428) Battery Replacement, Apply isopropyl alcohol: step 13, image 1 of 2 Kobo Libra Colour (N428) Battery Replacement, Apply isopropyl alcohol: step 13, image 2 of 2
    • The next five steps show how to remove the battery using isopropyl alcohol and a plastic card.
    • Apply a few drops of isopropyl alcohol under the edge of the battery closest to the white interconnect cable.
    Ask FixBot
  14. Kobo Libra Colour (N428) Battery Replacement: step 14, image 1 of 2 Kobo Libra Colour (N428) Battery Replacement: step 14, image 2 of 2
    • Tilt the eReader up to let the isopropyl alcohol flow under the battery.
    • Wait one minute for the alcohol to soften the adhesive.
    Ask FixBot
  15. Kobo Libra Colour (N428) Battery Replacement, Separate the adhesive: step 15, image 1 of 3 Kobo Libra Colour (N428) Battery Replacement, Separate the adhesive: step 15, image 2 of 3 Kobo Libra Colour (N428) Battery Replacement, Separate the adhesive: step 15, image 3 of 3
    • Slide a plastic card under the battery to separate the adhesive and the coating.
    • Don't bend or crease the battery! Avoid prying or lifting up with the plastic card.
    • If you're having trouble, apply a few more drops of isopropyl alcohol and try again.
    Ask FixBot
  16. Kobo Libra Colour (N428) Battery Replacement: step 16, image 1 of 2 Kobo Libra Colour (N428) Battery Replacement: step 16, image 2 of 2
    • Slide the plastic card under the opposite end of the battery to separate any remaining adhesive and coating.
    Ask FixBot
  17. Kobo Libra Colour (N428) Battery Replacement, Remove the battery: step 17, image 1 of 3 Kobo Libra Colour (N428) Battery Replacement, Remove the battery: step 17, image 2 of 3 Kobo Libra Colour (N428) Battery Replacement, Remove the battery: step 17, image 3 of 3
    • Lift the battery out of the frame and remove it.
    • Never reuse a soft shell battery! Even if your battery doesn't show any signs of damage, get a new one.
    • During reassembly, follow this guide to install a new battery.
    Ask FixBot
Remember: after repairs, your eReader is no longer IPX8 waterproof.
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
Make sure each of your device's main functions still work, e.g., LED backlight, touch, page-turn buttons, Wi-Fi, etc.
For optimal performance, calibrate your newly installed battery after completing this guide.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers Community for help.
4 other people completed this guide.
Alex Diaz-Kokaisl
244,661 Reputation
1,203 Guides authored
iFixit Member of iFixit
Staff
123 Members
27,624 Guides authored
2 Guide Comments
Hi hi. Does anyone know if this battery is compatible with the Kobo Libra 2 (B/W)? Thanks in advance for any help you can provide.
Rick Austin - Reply Share
No it is not! The Colour battery is massive.
The Libra 2 looks like this https://www.reddit.com/r/kobo/comments/1...
Get it on Aliexpress: https://www.aliexpress.com/item/10050079...
The first link above has a description of how to do it to avoid soldering the motherboard.
Andrew - Reply Share
Past 24 Hours: 30
Past 7 Days: 177
Past 30 Days: 712
All Time: 19,445
