Kobo Clara BW (P365) Front Cover Replacement
    1. Kobo Clara BW (P365) Front Cover Replacement, Before you begin: step 1, image 1 of 3 Kobo Clara BW (P365) Front Cover Replacement, Before you begin: step 1, image 2 of 3 Kobo Clara BW (P365) Front Cover Replacement, Before you begin: step 1, image 3 of 3
      • Drain your eReader's battery as much as possible before starting your repair. Ideally, it should be fully discharged.
      • Optionally, to drain the battery faster, navigate to MoreSettingsEnergy saving and privacy and set Automatically go to sleep after and Automatically power off after to Never.
      • When working on or near the battery, don't use sharp metal tools to avoid puncturing and shorting the battery.
      • Unplug all cables and fully shut down your eReader.
      • Your screen should be black and say Powered off.
      Ask FixBot
    1. Kobo Clara BW (P365) Front Cover Replacement, Insert an opening pick: step 2, image 1 of 2 Kobo Clara BW (P365) Front Cover Replacement, Insert an opening pick: step 2, image 2 of 2
      • Lay your eReader down so the back cover is facing up.
      • Insert the flat edge of an opening pick between the frame and the bottom left corner of the back cover.
      • Push the pick downwards at a slight angle until it slides under the back cover.
      Ask FixBot
    2. Kobo Clara BW (P365) Front Cover Replacement, Release the bottom clips: step 3, image 1 of 3 Kobo Clara BW (P365) Front Cover Replacement, Release the bottom clips: step 3, image 2 of 3 Kobo Clara BW (P365) Front Cover Replacement, Release the bottom clips: step 3, image 3 of 3
      • Slide the pick toward the bottom right corner to release the clips along the bottom edge.
      Ask FixBot
    3. Kobo Clara BW (P365) Front Cover Replacement: step 4, image 1 of 2 Kobo Clara BW (P365) Front Cover Replacement: step 4, image 2 of 2
      • Remove the pick and reinsert it under the bottom left corner.
      • Angle the pick flat under the back cover and rotate it around the bottom left corner to release its clips.
      • If you're having trouble, try twisting the pick to lift the corner clips out of their slots.
      Ask FixBot
    4. Kobo Clara BW (P365) Front Cover Replacement, Release the left clips: step 5, image 1 of 3 Kobo Clara BW (P365) Front Cover Replacement, Release the left clips: step 5, image 2 of 3 Kobo Clara BW (P365) Front Cover Replacement, Release the left clips: step 5, image 3 of 3
      • Slide the pick toward the top left corner to release the clips along the left edge.
      Ask FixBot
    5. Kobo Clara BW (P365) Front Cover Replacement, Remove the back cover: step 6, image 1 of 3 Kobo Clara BW (P365) Front Cover Replacement, Remove the back cover: step 6, image 2 of 3 Kobo Clara BW (P365) Front Cover Replacement, Remove the back cover: step 6, image 3 of 3
      • At this point, you should be able to grip the back cover and release its remaining clips. If not, slide a pick under the perimeter of the back cover until you can grip an edge.
      • Grip the left edge of the back cover and lift it away from the eReader to release the remaining clips.
      • Remove the back cover.
      • During reassembly, align the back cover over the eReader and press along the perimeter until all its clips snap back into place.
      Ask FixBot
    1. Kobo Clara BW (P365) Front Cover Replacement, Coating information: step 7, image 1 of 3 Kobo Clara BW (P365) Front Cover Replacement, Coating information: step 7, image 2 of 3 Kobo Clara BW (P365) Front Cover Replacement, Coating information: step 7, image 3 of 3
      • Nearly the entire surface of the eReader's internals is covered in a thin, plastic-like waterproof coating. Keep the following in mind as you continue disassembly:
      • While this won't hurt your device, removing the coating compromises the device to potential water damage.
      • The coating is brittle and can flake into many small pieces. Heating the coating helps, but working with it is still a time-consuming process.
      • The ZIF connector locking tabs are coated in a gel that can jam the hinge and keep the locking tab from completely unlocking. Make sure the tabs are completely upright before disconnecting any cables.
      • Depending on your repair, you might have to remove the coating completely from the connectors and their cables.
      • If at any point the coating becomes too difficult to work with, heat it for 90 seconds with an iOpener or a hair dryer.
      Ask FixBot
    2. Kobo Clara BW (P365) Front Cover Replacement, Disconnect the battery: step 8, image 1 of 2 Kobo Clara BW (P365) Front Cover Replacement, Disconnect the battery: step 8, image 2 of 2
      • Use a clean fingernail or the flat end of a spudger to pry up and disconnect the battery press connector.
      • Don't pull on what looks like a clear connector pull tab. The tab is secured to the socket gasket.
      Ask FixBot
    1. Kobo Clara BW (P365) Front Cover Replacement, Remove the front cover screws: step 9, image 1 of 2 Kobo Clara BW (P365) Front Cover Replacement, Remove the front cover screws: step 9, image 2 of 2
      • Use a Phillips screwdriver to remove the four 3 mm‑long screws securing the corners of the front cover.
      Ask FixBot
    2. Kobo Clara BW (P365) Front Cover Replacement, Separate the adhesive: step 10, image 1 of 3 Kobo Clara BW (P365) Front Cover Replacement, Separate the adhesive: step 10, image 2 of 3 Kobo Clara BW (P365) Front Cover Replacement, Separate the adhesive: step 10, image 3 of 3
      • The screen is secured by weak adhesive along the perimeter of the front cover and a layer of coating at the bottom edge.
      • Bend the top edge of the front cover around the screen to separate the adhesive.
      Ask FixBot
    3. Kobo Clara BW (P365) Front Cover Replacement: step 11, image 1 of 3 Kobo Clara BW (P365) Front Cover Replacement: step 11, image 2 of 3 Kobo Clara BW (P365) Front Cover Replacement: step 11, image 3 of 3
      • Lift the top edge of the screen to separate any remaining adhesive around the perimeter of the front cover.
      • Slide the screen toward the top of the eReader to expose the coating at the bottom edge.
      Ask FixBot
    4. Kobo Clara BW (P365) Front Cover Replacement, Remove the screen assembly: step 12, image 1 of 3 Kobo Clara BW (P365) Front Cover Replacement, Remove the screen assembly: step 12, image 2 of 3 Kobo Clara BW (P365) Front Cover Replacement, Remove the screen assembly: step 12, image 3 of 3
      Tool used on this step:
      Tesa 61395 Tape
      $2.95
      Buy
      • Lift and rotate the screen off the bottom edge of the front cover to separate the coating.
      • Remove the screen. Only the front cover remains.
      • During reassembly:
      • If your replacement front cover comes with pre‑installed adhesive, remove the liner. Otherwise, use a thin, double‑sided tape like Tesa Tape to replace the adhesive.
      • Align the front cover over the screen and press down around the perimeter until the clips snap back into place.
      Ask FixBot
Remember: after repairs, your eReader is no longer IPX8 waterproof.
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
Make sure each of your device's main functions still work, e.g., LED backlight, touch, Wi-Fi, etc.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers Community for help.
Carsten Frauenheim
171,253 Reputation
442 Guides authored
iFixit Member of iFixit
Staff
122 Members
72,303 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 18
Past 30 Days: 59
All Time: 509
