Kobo Arc K107 USB Replacement
  1. Kobo Arc K107 USB Replacement, Battery: step 1, image 1 of 1
    • Peel the back cover off of the Kobo Arc by finding the lip in the cover and pulling back on it.
    Ask FixBot
  2. Kobo Arc K107 USB Replacement: step 2, image 1 of 1
    • Remove the screws from the midframe.
    Ask FixBot
  3. Kobo Arc K107 USB Replacement: step 3, image 1 of 1
    • Use a nylon spudger to pry up the battery from the device.
    • It will give some resistance as it is glued down.
    • Always use plastic or nylon prying tools around the battery. Metal tools can puncture a battery, potentially causing a fire.
    Ask FixBot
  4. Kobo Arc K107 USB Replacement: step 4, image 1 of 1
    • Unplug the battery connector from the rest of the tablet.
    • Remove the battery from the tablet.
    Ask FixBot
  5. Kobo Arc K107 USB Replacement, USB: step 5, image 1 of 1
    • Remove the motherboard from the outer case.
    Ask FixBot
  6. Kobo Arc K107 USB Replacement: step 6, image 1 of 1
    • Detach the USB cable from the motherboard.
    • Remove the USB port from the tablet.
    Ask FixBot
Ray Starpoli
169 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 24
All Time: 693
