KitchenAid Professional 600 Top Cover Replacement
    1. KitchenAid Professional 600 Top Cover Replacement, Top Cover: step 1, image 1 of 1
      • Take out the screw which holds on the silver band using a Phillips #2 screwdriver.
      • Remove the silver band.
      Ask FixBot
    2. KitchenAid Professional 600 Top Cover Replacement: step 2, image 1 of 1
      • Remove the four Phillips #2 screws located around the mixer where the band was removed.
      • This picture only shows two of the screw that you need to remove. The other two are on the exact opposite side of the mixer.
      Ask FixBot
    3. KitchenAid Professional 600 Top Cover Replacement: step 3, image 1 of 1
      • Remove the top of the mixer to reveal the inner parts.
      • The top should lift off, but may not if it is stuck. A sharp strike from the back with the hand may unstick it. It will slide forward about a 3/8 of an inch. Push it back again from the front and it should be free enough to lift.
      Ask FixBot
4 other people completed this guide.
Luke
1,380 Reputation
5 Guides authored
Cal Poly, Team 25-4, Maness Spring 2016 Member of Cal Poly, Team 25-4, Maness Spring 2016
CPSU-MANESS-S16S25G4
4 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 6
Past 30 Days: 48
All Time: 3,825
