Up to 20% off select tools
KitchenAid Professional 600 Speed Selector Replacement
Views: 16K
View statistics:
Past 24 Hours:
11
Past 7 Days:
101
Past 30 Days:
334
All Time:
15,625
Comments: 13
5 comments on steps, 8 guide comments.
Go to guide comments
Completed: 4
4 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: No estimate
Difficulty: Easy
Parts
  • KitchenAid Part# WP9706648
    $69.99
    For compatible 120 V KitchenAid Professional 600 configurations. Replaces the 9707220 board pictured in this guide. Match the complete mixer model number and follow the replacement board’s wiring and motor-sensor instructions.
Tools
Introduction
Go to step 1 ↓
As an expensive mixer that is built to last, some key components do go bad from time to time. Overall, your investment, with a few fixes along the way, will nearly last a lifetime. This guide will demystify your repair to your KitchenAid Pro stand mixer.
    1. KitchenAid Professional 600 Speed Selector Replacement, Top Cover: step 1, image 1 of 1
      • Take out the screw which holds on the silver band using a Phillips #2 screwdriver.
      • Remove the silver band.
      Ask FixBot
    2. KitchenAid Professional 600 Speed Selector Replacement: step 2, image 1 of 1
      • Remove the four Phillips #2 screws located around the mixer where the band was removed.
      • This picture only shows two of the screw that you need to remove. The other two are on the exact opposite side of the mixer.
      Ask FixBot
    3. KitchenAid Professional 600 Speed Selector Replacement: step 3, image 1 of 1
      • Remove the top of the mixer to reveal the inner parts.
      • The top should lift off, but may not if it is stuck. A sharp strike from the back with the hand may unstick it. It will slide forward about a 3/8 of an inch. Push it back again from the front and it should be free enough to lift.
      Ask FixBot
    1. KitchenAid Professional 600 Speed Selector Replacement, Speed Selector: step 4, image 1 of 1
      • Locate the selector switch.
      • Remove the two Phillips #2 screws holding the selector switch in place.
      Ask FixBot
    2. KitchenAid Professional 600 Speed Selector Replacement: step 5, image 1 of 3 KitchenAid Professional 600 Speed Selector Replacement: step 5, image 2 of 3 KitchenAid Professional 600 Speed Selector Replacement: step 5, image 3 of 3
      • Label each wire by its terminal marking, then unplug the wires connecting the drive motor to the switch.
      • Replacement boards may use a different connector layout. Follow the wiring and motor-sensor instructions supplied with the replacement board.
      Ask FixBot
    3. KitchenAid Professional 600 Speed Selector Replacement: step 6, image 1 of 1
      • Pull out the Selector Switch.
      Ask FixBot
4 other people completed this guide.
Author
with
Tallon Dotinga
487 Reputation
2 Guides authored
Cal Poly, Team 25-4, Maness Spring 2016 Member of Cal Poly, Team 25-4, Maness Spring 2016
CPSU-MANESS-S16S25G4
4 Members
84 Guides authored
8 Guide Comments
The instructions are to unplug the cords from the motor but the removed selector switch pictured shows the cords were removed from the selector switch. Is there a way to remove the cords from the selector switch without breaking them? donmilo@yahoo.com
Don Singleton - Reply Share
The replacement part looks like a major part in the mixer and probably costs a bundle like most replacement parts… sometimes deems the replacement “not worthy” to repair!
It’s like a car that cost $25K but, all its parts if you buy them separately, it will cost you $150K !!!
david almogi - Reply Share
The speed selector MSRP is $89.99 and can be found on places like eBay for $35-60. For only needing some simple tools and a little time, this fix saves you from the cost of buying a new one. These are designed to be repaired/refurbished.
Rachel Johnson - Reply Share
When the speed selector is replaced, what is the rpm for “stir”?
everything is working, but it still seems too fast at 120rpm and I can’t see a difference between speeds 6, 8, & 10.
Jessica - Reply Share
The advice about kitchenaid600 switch was good. The form to get me able to say thanks was not.
What thehelldoyouwant - Reply Share
Past 24 Hours: 11
Past 7 Days: 101
Past 30 Days: 334
All Time: 15,625
