KitchenAid Professional 600 Power Cord Replacement
Views: 7.7K
View statistics:
Past 24 Hours:
2
Past 7 Days:
23
Past 30 Days:
104
All Time:
7,690
Comments: 8
6 comments on steps, 2 guide comments.
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Introduction
Go to step 1 ↓
This guide will provide a detailed step-by-step instruction guide on how to remove the power cord from the KitchenAid Professional 600.
Tools
    1. KitchenAid Professional 600 Power Cord Replacement, Top Cover: step 1, image 1 of 1
      • Take out the screw which holds on the silver band using a Phillips #2 screwdriver.
      • Remove the silver band.
      Ask FixBot
    2. KitchenAid Professional 600 Power Cord Replacement: step 2, image 1 of 1
      • Remove the four Phillips #2 screws located around the mixer where the band was removed.
      • This picture only shows two of the screw that you need to remove. The other two are on the exact opposite side of the mixer.
      Ask FixBot
    3. KitchenAid Professional 600 Power Cord Replacement: step 3, image 1 of 1
      • Remove the top of the mixer to reveal the inner parts.
      • The top should lift off, but may not if it is stuck. A sharp strike from the back with the hand may unstick it. It will slide forward about a 3/8 of an inch. Push it back again from the front and it should be free enough to lift.
      Ask FixBot
    1. KitchenAid Professional 600 Power Cord Replacement, Speed Selector: step 4, image 1 of 1
      • Locate the selector switch.
      • Remove the two Phillips #2 screws holding the selector switch in place.
      Ask FixBot
    2. KitchenAid Professional 600 Power Cord Replacement: step 5, image 1 of 3 KitchenAid Professional 600 Power Cord Replacement: step 5, image 2 of 3 KitchenAid Professional 600 Power Cord Replacement: step 5, image 3 of 3
      • Unplug the cords attaching the drive motor to the switch.
      • We suggest numbering them left from right so they are reattached to the replacement part in the right order.
      Ask FixBot
    3. KitchenAid Professional 600 Power Cord Replacement: step 6, image 1 of 1
      • Pull out the Selector Switch.
      Ask FixBot
    1. KitchenAid Professional 600 Power Cord Replacement, Drive Motor: step 7, image 1 of 1
      • Remove the two Phillips #2 screws holding the motor in place, located near the fan at the back of the motor.
      • The picture only shows one of the screws. The other screw is located on the exact opposite side of the motor.
      Ask FixBot
    2. KitchenAid Professional 600 Power Cord Replacement: step 8, image 1 of 1
      • Pull upward to remove the motor.
      Ask FixBot
    1. KitchenAid Professional 600 Power Cord Replacement, Power Cord: step 9, image 1 of 1
      • Remove the Phillips #2 screw attaching the green grounding wire to the frame of the mixer.
      Ask FixBot
    2. KitchenAid Professional 600 Power Cord Replacement: step 10, image 1 of 1
      • Remove the three Phillips #2 screws that connect the top portion of the mixer to the "neck" of the mixer.
      Ask FixBot
    3. KitchenAid Professional 600 Power Cord Replacement: step 11, image 1 of 1
      • Remove the top portion of the mixer from the "neck" of the mixer.
      • This will make removing the power cord much easier.
      Ask FixBot
    4. KitchenAid Professional 600 Power Cord Replacement: step 12, image 1 of 1
      • You can now remove the power cord from the mixer.
      Ask FixBot
Luke
1,380 Reputation
5 Guides authored
Cal Poly, Team 25-4, Maness Spring 2016 Member of Cal Poly, Team 25-4, Maness Spring 2016
CPSU-MANESS-S16S25G4
4 Members
84 Guides authored
2 Guide Comments
So helpful thank you. I've got my mixer cord changer and the mixer is working now. Unfortunately there's always only one speed, high. Any suggestions?
Britter C - Reply Share
Any idea where I can buy the power cord itself?
Jaeger Amzallag - Reply Share
Past 24 Hours: 2
Past 7 Days: 23
Past 30 Days: 104
All Time: 7,690
