KitchenAid KSB5CR Ribbon Cable Replacement
  1. KitchenAid KSB5CR Ribbon Cable Replacement, Removing the Back Panel Part 1: step 1, image 1 of 3 KitchenAid KSB5CR Ribbon Cable Replacement, Removing the Back Panel Part 1: step 1, image 2 of 3 KitchenAid KSB5CR Ribbon Cable Replacement, Removing the Back Panel Part 1: step 1, image 3 of 3
    • Remove the glass container and place the blender upside down on a solid surface.
    • Remove the four rubber feet using the needle nose pliers.
    • Remove the four #7.5 Phillips 25mm screws that were located underneath the rubber feet using the Phillips #2 screwdriver.
    Ask FixBot
  2. KitchenAid KSB5CR Ribbon Cable Replacement, Removing the Back Panel Part 2: step 2, image 1 of 1
    • Lift the back panel up, sliding it along the power cord.
    Ask FixBot
  3. KitchenAid KSB5CR Ribbon Cable Replacement, Removing the O-Ring: step 3, image 1 of 2 KitchenAid KSB5CR Ribbon Cable Replacement, Removing the O-Ring: step 3, image 2 of 2
    • Remove the two #6 Hex 82mm screws using the Phillips #2 screwdriver.
    • Remove the rubber O-ring by lifting it up.
    Ask FixBot
  4. KitchenAid KSB5CR Ribbon Cable Replacement, Removing the Ribbon Cable: step 4, image 1 of 1
    • Remove the ribbon cable from the chassis by lifting it up.
    • Remove the other end of the ribbon cable from the circuit board by lifting it up.
    Ask FixBot
Cameron Geehr
745 Reputation
6 Guides authored
Cal Poly, Team 12-5, Forte Fall 2014 Member of Cal Poly, Team 12-5, Forte Fall 2014
CPSU-FORTE-F14S12G5
5 Members
12 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 17
All Time: 747
